Broken SX key and prop plug?!
The SX forum doesn't get much traffic and this is more of a general question any. I think my SX key is broken. I just pulled it off my shelf to start a bit of learning and when plugged in vista says it can't recognize the device and SX software doesn't find any COM ports. The SX key also seems to be warm to the touch and I don't know if it used to do this. Is there any way to fix it if it's broken?
WHAT? Now my propeller plug is doing the same thing...
Ok so I moved both of them to another computer. The Prop Plug worked. Then The SX key worked for about 5 sec then XP said that it malfunctioned. Plugged the PropPlug back in and it didn't work. So Now I am suspecting the SX Key is blowing my USB ports. But I plug the PropPlug back into vista and it works. Plugged it back into XP and it doesn't work.
What is going on?!
What is going on?!
When you are plugging in the SX-key and it gets hot do you have it plugged into your target board with the SX or does it also get hot just plugged into the computer?
Robert
But since I got it working time was not of the essence. Thank you for your concern on answering me quickly however!
It gets warm when the connected to the comp over USB whether in the target board or not. I was also having some difficulties with Debugging. Is The SX key just super susceptible to timing variations that can cause errors? But then that doesn't answer why the PropPlug stopped working for a bit.
But the SX Key does heat up just being plugged in by USB? Could someone double check for me?
Thanks!
I doubt that the IDE would be the problem because you have two different IDEs for the Propeller and the SXes.
Since the Prop plug runs cooler, get that working first. Some SXKeys do run hot, but the crystal or resonator should be removed from the board during their use.
