StringSend(0, string("This page has been served "))
StringSend(0, string("<b>"))
StringSend(0, STR.numberToDecimal(PageCount, 5))
StringSend(0, string("</b>"))
StringSend(0, string(" times since powering on of the module"))
I am getting a prepended " " space in front of the numbers so I need to either use a different function, modify it or parse out the first char - as HTML DOM element identifiers in my pages were being rendered incorrectly.
My next demo version should have it fixed.
The following
Is rendered as
But needs to be
The following overloaded function may be added to STREngine.spin - normally I would have one call the other with a parameter
thank you
/michael
I hadn't looked at the object close enough.
OBC
i changed line
358 to bytemove(@decimalCharacters[0], @decimalCharacters[(11 - length)], (length + 1))
from bytemove(@decimalCharacters[1], @decimalCharacters[(11 - length)], (length + 1))
this solved the issue of me with the " "
