cogs calling cogs — Parallax Forums
cogs calling cogs
steprogsteprog Posts: 227
edited 2010-11-21 19:12 in Propeller 1
Hello Everyone,
I have a question. My main program calls and creates several methods in different cogs. How do you get one of these method (or cogs) to be able to use another method or cog also called by the main program.
For instance, I am calling a 2 TEC drivers, each uses the PWM_32_V2 method. To use just one cog I call it from the main or cog 0. How am I able to use the PWM_32_V2 from my TEC driver cogs?
Any Ideas?
    edited 2010-11-21 11:37
    steprog wrote: »
    Hello Everyone,
    Any Ideas?
    Can't be done directly. You can have a memory location in the hub where one cog [cog 1] leaves a command or data for another cog [cog 2]. Cog 2 would check that hub location and execute that command or read that data and perform whatever function was required.
  • steprogsteprog Posts: 227
    edited 2010-11-21 12:46
    Thats too bad. It seems that it would create some pretty awkward code.
    edited 2010-11-21 13:48
    Truth is, it produces very modular and reusable code.
    Consider the TV.spin and Graphics.spin objects authored by Chip. TV.spin is used by graphics_demo.spin, and TVtext.spin, unchanged! The same goes for VGA objects, many capable of using graphics.spin. (all about screen formatting really)
    If one wants multiple displays, just launch a few of them, allocate some RAM to communicate to them, and then use just ONE graphics.spin to serve images to all of them.
    It's just a different way of thinking, that's all. It's only awkward because these kinds of things are more difficult on other kinds of processors, making it unfamiliar.
    edited 2010-11-21 14:00
    I guess, but it seems that in this particular case it is not very efficient to the point of having to launch 2 cogs instead of one
    edited 2010-11-21 14:02
    As potatohead says it produces very modular and reusable code. It also makes for much more deterministic timing and pipelined or parallel processing of data. Prodicing video and sending serial data is greatly simplified. It also makes dividing functions between cogs and controlling them easier. You can have a spin program control functions in multiple cogs or you can have a chain of cogs doing partial processing of data and passing it to the next cog in line.
  • MagIO2MagIO2 Posts: 2,243
    edited 2010-11-21 14:05
    Just for your understanding:
    If you use one object in 2 different .SPIN-files
    1. the code is not duplicated
    2. DAT sections are not duplicated
    3. only the VAR section is duplicated
    Some drivers - propably like the PWM-driver - are designed to allow COGs to run them independently. That's why it's easy to set up several serial interfaces with FullDuplexSerial.
    Other drivers, like the graphics-driver are designed to run only once and allow usage from more than one other COG.
    The difference is that the first kind of drivers uses VARs, the second kind of drivers uses DAT or some memory directly.
    So, if you have a driver of one kind you can also convert it to the other.
    If two functions are required a cog could do both if there is enough cog memoy available.
    edited 2010-11-21 14:16
    There maybe another way for me to rewrite my code. I will look into that. It still bugs me a little that I can't access another method directly, but I think I'm just getting spoiled using the prop.
    edited 2010-11-21 14:40
    Object A:
    Using Object B and Object C
    Object B:
    Using Object C
    In this constellation both, object A and object B have access to the functions of object C. Please note, that the code is not duplicated in the available RAM. It's there only once. Same is true for the DAT variables. Only VAR variables are duplicated.
    The implementation of object C makes the difference. If C makes use of VAR, each instance of the object is functioning independent - because each instance has it's own state. If C only uses DAT (or memory directly) it's more like one global object.
    If C is a global object you have to be carefull when running the C functions in parallel (from several COGs at the same time). Depending on what the object is doing you might want to use LOCKs for synchronizing.
    edited 2010-11-21 15:36
    My situation is the following
    Object A -->PWM
    --> TEC control (where each wants to use PWM)
    solution (not desirable, uses 2 cogs when only one is needed)
    Object A
    --> TEC control --> PWM
    --> TEC control--> PWM
    It would be nice to only use 1 cog instead of 2 here.
  • Kal_ZakkathKal_Zakkath Posts: 72
    edited 2010-11-21 16:40
    Disclaimer: I don't have access to the PWM object (or a prop board) right now to check what I'm saying.
    I believe you have two choices here:
    1. As others have mentioned, some objects are already designed to be called from multiple cogs. Assuming that the PWM object allows for this, your solution would be correct but only one of the TEC control objects would need to call pwm.start - or you could do it in Object A before getting into TEC control (so pwm is only running in one cog, the other TEC control object shares that same instance).
    2. If you define everything in one object file, then the different cogs can access the variables and objects declared in that file (like your first diagram, if TEC control and Object A are merged into the same file).
    #1 would probably be considered best practise, and would result in cleaner and more re-usable code (though may require more coding). #2 can be done though (you will of course still have to ensure that having multiple cogs calling a single instance does not cause any problems).
    edited 2010-11-21 16:57
    steprog, since PWM_32_V2 can have up to 32 independent PWM outputs it seems your problem starts with having to run 2 copies of the TEC controller. Is the TEC controller something you have written?
    edited 2010-11-21 17:06
    Yes I wrote the TEC drivers. I "started the "pwm" object in my main program and then launched my TEC drivers. However doing pwm.duty... gave me an error. Basically, the child objects couldn't see the pwm object. I'm guessing that means I can't access this cog or method from the TEC drivers.
    edited 2010-11-21 18:36
    Are you saying if I launch the PWM object then only one instance is ever started? How do you talk to that object?
    edited 2010-11-21 19:09
    You need to include it in the OBJ of any object you want to use it in, otherwise the compiler does not know what you are talking about (since 'pwm' means as much as 'xyz' to the compiler).
    Note that this does not mean that it is using a cog - calling the start() method (or similar, provided it is following good coding practise) is where it launches off another cog (if the object needs one).
    Put another way: If you only call start() on the pwm object once, then it will only be using one cog, no matter how often it is listed in OBJ blocks in your other objects.
    I will give that a try.
