Exporting .PDF from DipTrace — Parallax Forums
hmlittle59hmlittle59 Posts: 404
edited 2010-11-18 09:27 in General Discussion
Hello All,
Has anyone ever exported their Diptrace sch./PCB file for loading into Adobe?
Howard
  • wjsteelewjsteele Posts: 697
    edited 2010-11-18 06:36
    hmlittle59 wrote: »
    Howard, there is a free printer driver called PDF995 that allows you to print any document to a PDF file. I'm sure you can use it.
    Bill
    edited 2010-11-18 06:48
    Also one called PDFCreator.
  • LeonLeon Posts: 7,620
    edited 2010-11-18 07:24
    I used to use PrimoPDF with the Pulsonix PCB software, until they provided PDF export. It worked very well.
  • hmlittle59hmlittle59 Posts: 404
    edited 2010-11-18 07:30
    Hello All,
    will download them all
    thanks a bunch
    Howard
    Another for the pile, cutepdf. Been using it for years and my entire company uses it as the standard PDF creator. I only use my Adobe Pro PDF creator when I need to do all the fancy PDF things like bookmarks, file merging, etc.
