A Couple Prop1<-->Prop2<-->Prop3 Inter-Communication Questions
idbruce
Hello Everyone
I have three Propeller Proto Boards that must communicate with each other.
Here is the setup:
Prop1 must be able to communicate with Prop2
Prop2 must be able to communicate with Prop1 and Prop3
Prop3 must be able to communicate with Prop2
Prop1, Prop2, and Prop3 all have the same _CLKMODE and _XINFREQ constant settings
_CLKMODE = XTAL1 + PLL16X
_XINFREQ = 5_000_000
From the documentation that I have read, I am assuming that I can accomplish this task in the following fashion.
Prop1 has 1 object of FullDuplexSerialPlus
Prop1ToProp2 : "FullDuplexSerialPlus"
Intialize pins 0 and 1 in the start method
Prop1ToProp2.start(0, 1, 0, 9600)
Prop2 has 2 objects of FullDuplexSerialPlus
Prop2ToProp1 : "FullDuplexSerialPlus"
Prop2ToProp1.start(1, 0, 0, 9600)
and
Prop2ToProp3 : "FullDuplexSerialPlus"
Intialize pins 2 and 3 in the start method
Prop2ToProp1.start(2, 3, 0, 9600)
and finally
Prop3 has 1 object of FullDuplexSerialPlus
Prop3ToProp2 : "FullDuplexSerialPlus"
Prop3ToProp2.start(0, 1, 0, 9600)
As I understand it, it is simply a three wire connection between each Prop, a TX line, a RX line, and a common ground. The distance from Prop1 to Prop2 will be approximately four inches, and the connection will consist of three stranded 22 AWG wires in a cable sheathing. The distance from Prop2 to Prop3 will be approximately three feet, and the connection will consist of a four conductor 28 AWG DIN cable assembly.
Okay, there is the proposed layout. Now for the questions.
1. Can I achieve inter-communication as described above?
2. If I am correct in the proceeding assumptions, are there any special wiring requirements that I must be aware of? I assume it should be pin to pin connections, without any need for resistors, capacitors, etc.
3. Again, if I am correct in the proceeding assumptions, what would be the approximate maximum BAUD rate with the described connections?
Any assistance you may provide will be greatly appreciated.
Bruce
Here is the setup:
and
and finally
Bruce
Baud rate ? 9600 ?... you set it. Make a diagram of the 3 propellers, if you connect them right the output of one to the input of the other one it should work well, and the GNDs of course too.
Have fun
Mike -> My programming is always error free
Bruce
It's made my life a lot easier. Thanks Tim.
It's in the OBEX.
Duane Degn
Duane Degn - Thanks for the info. I haven't yet begun to get into the intricacies of programming the boards, but I believe I should have an ample amount of cogs. However, you are correct, if I run low on cogs, Prop2 will be the place. Thanks.
