Your Humidity Sensor Experiences? — Parallax Forums
ercoerco Posts: 20,263
edited 2010-11-17 08:32 in General Discussion
I've been planning to install automatic switches on two bathroom exhaust fans so they turn on when people take showers. My plan is to duplicate a thermistor circuit that has worked perfectly for years in my living room, which turns on several ceiling fans when my natural gas floor furnace kicks on. In that app, I installed a thermistor on the exhaust duct, which gets hot from gas combustion. The thermistor is connected to a simple LM339 comparator so that it closes the fan relay any time the exhaust duct gets above ~110 degrees. I can install similar thermistors on the bathtub hot water supply line so that any time the pipe is above ~110 degrees (hot water flowing) the exhaust fan comes on. A pot adjustment allows fine tuning, which keeps the fan running for a while after the shower water flow stops and the pipe cools down.
But I just saw Parallax' DoD today, which is the humidity sensor. A variable capacitance sensor which I have never tried. Could also probably work in this app. Anyone have any experience or recommendations with this particular sensor?
http://www.parallax.com/Store/Sensors/TemperatureHumidity/tabid/174/ProductID/554/List/0/Default.aspx?SortField=ProductName,ProductName
    edited 2010-11-16 18:13
    Not to denigrate Parallax's offerings or one's do-it-yourself inclinations, but I've had a Honeywell humidistat (now discontinued) installed inline with my bathroom fan for years, and it "just works"TM. There are less expensive ones available now that will probably work just as well.
    I'd say the particular humidity sensor you ask about is quite robust. I have the other, I believe it is a Sensitron temperature and humidity sensor and it seems good, but I fear it may not be as durable due to the different kind of humidity sensor it provides.
