Boe Bot Jerky Turns — Parallax Forums
Boe Bot Jerky Turns
anbotanbot Posts: 2
edited 2010-11-09 19:01 in Robotics
Is there a way to eliminate the jerkiness when the BOE Bot takes a turn while line following? I have tried both speeding up and slowing down the outside as well as the inside servos and there doesn't seem to be any difference.
    edited 2010-11-05 18:18
    It's hard to comment without seeing your code. You might have a bug or some other fix might occur to us.
    edited 2010-11-09 13:35
    Code is only one part of the problem. Reliability, speed, and smoothness of line-following are related to a lot of physical factors, such as chassis geometry, mass, traction, wheel size, distance between wheels, CG, supply voltage, number of optical sensors, sensor location WRT to the axle. A BoeBot is a great all-purpose learning platform for many tasks. Compare it to Pololu's 3Pi robot, which is optimized to haul Smile in line-following mode. Of course it has 5 line sensors and a voltage booster to help boost performance:
    http://www.youtube.com/watch?v=mJV-KDqHgDQ
    http://www.youtube.com/watch?v=a7CKLmIzHXM
    @erco, the 3Pi is one crazy fast robot.
