Spinneret: First Impressions
Phil Pilgrim (PhiPi)
I received a preview sample of the Spinneret today, which I wanted to test with a couple daughterboards to verify the Spinneret's daughterboard interface. So far, so good. Here's a photo of the Spinneret with a prototype XBRF-DB plugged in:
It worked fine, and I was able to commmunicate between the Prop and a USB XBee adapter, using this program:
Some observations:
1. The Spinneret board looks very nice and has a clean layout.
2. The board came without any screws or standoffs for a daughterboard. These should be included, since they're not provided with the daughterbaords. (Both the MoBoStamp-pe and Propeller Backpack include this hardware.)
3. The board is too wide (1.365") to fit the Parallax extrusion, which specs a 1.35" width. (To be fair, this may be because I don't have a production board. These boards are assembled in panels which have been scored. My board had been broken out of the panel, but the edges were not sanded flat, and that may account for the extra width.)
'More testing to do, but I can tell already: this is going to be a great product!
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
sio : "FullDuplexSerial"
PUB start | c, f
sio.start(26, 27, 0, 9600)
repeat
sio.tx(sio.rx)
Some observations:
Thanks, David!
OK, but what about that little XBee adapter board you're showing off in the photo up top? I think we need that in our inventory lineup just for this product. I'd like them in blue, please! The holdup on these can't be as complex as the PropCam. PropCam. PropCam.
But seriously, I do have a long list of things that need finishing, and with the S2 almost put to bed, there will be time to do it. I may yet surprise you with a load of PropCAMs! (But don't tell anyone in the forum I said that.)
