read back
Hello everybody,
Who knows a way to read back the contents of a working propeller? To be more precice: I would like to read which programm is in the propellerchip.
Thanks!
Thanks!
1) It will not give you Spin source code, as it is byte codes + pasm + data
2) You cannot easily modify it (see 1 above)
3) If it is someone else's product, you can't just copy it
Here's what I found when looking for docs for you:
http://forums.parallax.com/archive/index.php/t-106525.html
' LED sequencer on P16..P23 main | led dira[16..23]~~ repeat repeat led from 16 to 23 outa[16..23]~ outa[led]~~ waitcnt(cnt+40_000_000)
