Uneven brightness of the LED matrix display?
Hello there,
I just constructed a simple LED matrix display, and found something funny there - the brightness of these LEDs are uneven.
For example, I put a pattern which is the "1" on these LEDs, and the stem of the "1" seems dimmer (column with more LED lit) and the sides (column with less LED lit).
How could I make it to have the same brightness for all the LEDs inside?
By the way, I'm using the 74HC595 for the column drivers, and the ULN2803 to sink the currents. Tried removing the ULN2803 - no effect.
Any ideas for LED matrix for Prop systems? Thanks.
It would be a guessing game without some form of wiring diagram, schematic; and the code that is driving it.
Jim
I suspect that if the LED matrix is driven at something higher - say 9-10vdc and the current limiting resistors and pulse width is tweaked, you will get consistent brightness. I have spent a lot of hours trying to squeeze out a 5 volt solution and it just is too marginal.
Speculative answers have been offered, as I said, it's a guessing game, but you need to provide some hardware information. What is the current draw on the LEDs. Better yet, can you supply a data sheet for the LEDs, wiring, and code?
Edit : The ULN2803 should be drawn with +5V and also a ground, which I accidently left when I draw the diagram. In the prototype, I've connected it the supply and ground to the sink driver.
I'm scanning the rows using the 74HC595. One at the time.
Or must I use the CD4017?
Edit: The currents are then drained through ULN2803 which serves as a column driver too.
At any rate, if the 'HC595 is driving the columns in series and the ULN2803 is sinking the rows in parallel, your resistors need to be in series with the ULN2003 outputs, not the 'HC595 outputs.
But it would be much better to keep your current configuration and drive your columns in parallel with the 'HC595 and one row at a time with the ULN2003. The reason is that whichever device is driving one row or column at time might have to sink or source the current from 8 LEDs at once. The ULN2803 is much better equipped to do this than the 'HC595.
My mistakes on the first post - It should be the 74HC595 driving the rows (because of the anodes), and the ULN2803A with the columns (because of the cathodes).
I've checked around - most of the home made displays used this configuration. However, I may be wrong here. I based my design on that diagram below:
In any event, whatever the 'HC595 is driving, it needs to drive as many as all eight of them at once. The ULN2803 can drive only one of its constituent outputs at a time.
Sorry for the confusion. I have slightly modified the contents in the diagram. Mine is using the 8x8 Matrix instead of the 5x7 matrix, and on times, the rows and columns can be confused because the 8x8 matrix is an entire square.
In my very own circuit witn the 8x8 matrix , the rows are driven using 595s and the columns are sinked using the ULN2803.
What's happening in your present situation is that the 'HC595 may have to drive 8 paralleled LEDs at once, though a single resistor. This is a problem for two reasons:
1. HCMOS devices are not capable of high current output, and
2. The LEDs are being driven in parallel without individual load-limiting resistors. Because their forward voltages can vary slightly, some will draw more current (and be brighter) than the others.
Scanning one ULN output at a time with the 'HC595 outputs in parallel will solve both problems.
Thanks for the opinions. I need to redo the design. Hold on while I fix the drivers.
Edit: This solves the problem - however, there is one funny little problem.
As you can see in the photos enclosed, it shows the number one nicely - but the end of the number one has some trails of dimly-lit LEDs inside. It looks like it's ghosting effect. I also have to enclose the program code here. Another picture is just the inverted version of the first one to show that there are still trails of that dim LEDs there.
To remove the ghosting with the hardware in the schematic you posted earlier you need the 595 register latch clock and new row address to be output simultaneously. That requires removing lines 50 & 51 and replacing lines 30 35 in the current program.
repeat [color=red]shift(col_data[col_num]) outa[16..23] := rows_num[/color] rows_num := rows_num << 1 col_num++ if rows_num > 128 rows_num := 1 col_num := 0 waitcnt(50_000 + cnt)You're shifting new data into the '595 and displaying it while the old value is still present in the ULN. You need to turn off the ULN entrely (i.e. outa[16..23]~), then shift data into the '595 and latch it, then turn the ULN back on with the new data.
Or, better yet:
1. Shift data into '595.
2. Turn off ULN outputs.
3. Latch data in '595.
4. Set new ULN output.
This will help to reduce flicker.
I'll post the simple driver code here later as I need to housekeep the codes so that it is readable.
One thing is, now I'm thinking of putting a pool of characters, A-Z and 1,2...,and to 0 (and all the other things like symbols) inside the Prop. Or should I place them in a seperate EEPROM? :smilewinkgrin:
Besides the casual 5x7 fonts, any other stylish fonts to be fit into the LED matrix? I prefer the "blackboard bold" style, found it in the net one day but I forgot to bookmark it...
Welcome. It's a very very common project among many microcontroller hobbyists, and even college projects. One of the college projects I've seen is the LED matrix, but using PIC microcontrollers.
Multiplexing is generally done at these LED matrix displays. That goes the same for the seven-segments too. (the older one with the nixies are different though, these are interfaced with 7447s IIMNM)
