Need to concatenate a string, #1+#2+#3=#123. Help!
[EDIT] i changed the title of this thread just because i didnt feel starting a new one was necessary. original title was: "Need a way to take 4 numarical ASCII chars and convert to a real number" the new issue im having is that i need to take and array of bytes
eg. Byte Variable[2]
Variable[0] = 1
Variable[1] = 2
Variable[2] = 3
and concatenate them into one Long so that the long equals the actual number #123
[original thread]
lets say im using a terminal program and i enter 1234,
how could i convert %00110001_00110010_00110011_00110100 (or ascii 1234)
to the actual number %00000000_00000000_00000100_11010010 (or #1234)??
only way i can think is to make a lookup table.. is there any easier methods anyone knows about?
Thanks!!!
Variable[0] = 1
Variable[1] = 2
Variable[2] = 3
[original thread]
Thanks!!!
so think of N.Byte[n] as an array..
N.byte[0] = 1
N.byte[1] = 2
N.byte[2] = 3
N.byte[3] = 4
but now im a little stumped, any ideas on how to take 1, 2, 3 and 4 and make them = 1234??
heres the code by the way:
PUB ASCIIToNum(bytecnt) | C, N C := 0 data := 0 Repeat RXbyte := Debug.RXcheck If RXbyte => 0 Case RXbyte N0[0] : N.byte[C] := N0[1] N1[0] : N.byte[C] := N1[1] N2[0] : N.byte[C] := N2[1] N3[0] : N.byte[C] := N3[1] N4[0] : N.byte[C] := N4[1] N5[0] : N.byte[C] := N5[1] N6[0] : N.byte[C] := N6[1] N7[0] : N.byte[C] := N7[1] N8[0] : N.byte[C] := N8[1] N9[0] : N.byte[C] := N9[1] $0D : c := (bytecnt - 1) other : Debug.Str(String("Error, not a valid number character!!")) return if c => (bytecnt - 1) ????????Dont know what to do here?????? return C++ DAT N0 byte $30, $00 N1 byte $31, $01 N2 byte $32, $02 N3 byte $33, $03 N4 byte $34, $04 N5 byte $35, $05 N6 byte $36, $06 N7 byte $37, $07 N8 byte $38, $08 N9 byte $39, $09PRI cnv(addr) | c repeat while c := byte[addr++] result := result * 10 + (c - "0")either way you did give me an idea for a better way to collect those ascii bytes and convert them to actual numbers.
VAR byte AsciiNumbers[9] PUB ASCIIToNum(DecimalCount) | C, N Repeat C from 0 to 9 AsciiNumbers[c] := 0 C := 0 data := 0 Repeat RXbyte := Debug.RXcheck If RXbyte => 0 case RXbyte $30..$39 : AsciiNumbers[c] := RXbyte - $30 $0D : c := (DecimalCount - 1) other : Debug.Str(String("ERROR")) return if c => (DecimalCount - 1) repeat c from 0 to (DecimalCount - 1) Debug.str(num.tostr(AsciiNumbers[c], num#hex)) return C++that is so much smaller and can read more ascii bytes thus making much larger numbers!
but im still stumped on how to make 1 + 2 = 12???????????
CON _clkmode = XTAL1|PLL16X _xinfreq = 5_000_000 OBJ Debug: "FullDuplexSerial" PUB null Debug.start(31, 30, %0000, 115200) waitcnt(clkfreq*5 + cnt) repeat Debug.dec(cnv) Debug.tx(13) PUB cnv | RXbyte repeat RXbyte := Debug.RX case RXbyte "0".."9": result := result * 10 + (RXbyte - "0") other: return DAThey man thanks for the input, the code you posted looks oddly familiar to the code i just posted, proof that great minds do think alike!
[edit] well it did look similar for a second there, but i guess you're currently editing it :P
its not the conversion of an ascii byte to a single digit number thats causing me grief, its more or less the process of concatenating those collected bytes into a number inside of a Long
eg. #1 + #2 + #3 + #4 = #1234 (not #10)
PUB cnv | RXbyte repeat RXbyte := Debug.RX ' blocking call case RXbyte "0".."9": [COLOR="Red"]result := result * 10 + (RXbyte - "0")[/COLOR] other: return- result starts with 0 and will now be 0 * 10 + 1 = 1
- result = 1 * 10 + 2 = 12
- result = 12 * 10 + 3 = 123
- result = 123 * 10 + 4 = 1234
- loop breaks (CR is not in [0..9]) and result is returned as 1234
I just re-used it for convenience.i must have been looking at this from a totally different angle and didnt grasp the simplicity of your example untill i actually plugged it in and gave it a go.
guess thats what sleep deprivation, 5am, no coffee and a boss whos giving unreal deadlines will do to a fella..
Thank you!!
