Hi-Tech Caulking Gun!
Not only has the caulking gun gone cordless, but it's on sale for just $26!
http://cgi.ebay.com/Black-%26-Decker-CG100-Cordless-Caulk-Gun/320613155964?_trksid=p1468660.m2000036
For those who can't be bothered to pull a trigger... oh wait, there's still a trigger switch on this one. At least it's cordless... oh wait, there has never been a corded caulking gun. At least it's cheap... oh wait, a regular caulking gun costs $2...
Maybe we can gild the lilly by adding some LEDs and a Propeller chip...
I believe there are industrial pneumatic ones that are quite sturdy and used in factory settings.
I used one for caulking work when I did the finishing work on my apartment a few years ago, and when you have to leave an even bead of silione along a 2meter high vertical edge, you really want something motoried. (That was a corner of my shower stall. Quite a mess to get a decent bead all along the edge)
And if you use a caulking gun for an hour or two, you'll soon feel it in your hands.
(Imagine working on replacing window panes in a greenhouse or something... )
So, yeah, there's an actual market for these.
As for the '$2' guns...
I had one of those. The disc on the pushrod slipped aside and pushed past the plastic lid in the tube instead of pushing it in. Wasted half a tube of tile grouting. Never again.
When I bought a replacement tube, I also got hold of a GOOD caulking gun.
I have seen these in use many times. People that do a lot of cocking(window installers) use them to get perfectly even job every time. For me(a comercial electrician by day) there is no need since the only times I use one is to seal a hole i pounded through a roof or wall. usually with fire stop which the more the better.
I don't see it listed, but if it doesn't have a back-off feature, expect it to be messy. The push rod should be pulled back off the tube's plug when the trigger is released. Also, the long trigger would be annoying. The only purpose of a long trigger on a caulking gun is to give you the leverage you need. Ours look exactly like cordless drills and have a small, variable speed trigger.
For a perfect caulk, I have often seen masking tape used to make the margins perfect and then one pulls something to flatten the caulk after it is dispensed for a perfect look. This is often done in restaurant installations, where beauty and cleanliness are important.
Another way of getting better results is to push the tip through the outflow rather than pull. This seems to level the ripples in feed.
I am sure others have their own preferred means of caulking. I just happen to be a great believer in hand tools and trade skills rather than always turning to a power tool to solve the problem. After all, a good solution is only partially due to the tool and partially due to the technique.
I find it amazing how much beautiful woodwork has been produced without power tools AND especially without sandpaper. Sandpaper is great for refinishing auto paint and preparing rusted steel, but nearly completely unnecessary with a natural wood finish. But if I tell you how to do without it, I'd have to kill you.
