I need a push/push electro magnet
I need to build a system that will push an object approximately 2-3 inches, and then pull the object back at a later time. The forced needed to push and pull the object may range from 5 - 10lbs. It will probably need to have some PWM control so that it is not so abrupt, and the motion can be ramped a little to avoid a collision, it can't run just full on or full off. There are numerous electromagnet examples online with a coil wrapped around an iron rod.
Some questions I need to solve tomorrow:
Will this require that the object being moved have a permanent magnet on it so that positive and negative force can be exerted on the object by flipping the current?
Will driving the magnet with 24vdc and a mosfet off a Prop be able to move the object. I am assuming that the magnet will behave just like a motor, requiring the polarity to be swapped on the coil for each direction.
How much magnet wire(length) would be required to exert 10 lbs force?
Thanks for any suggestions before I head out to find parts to test this out.
BTW The reason I can't just use a stepper or DC motor instead is that once the object gets pushed out by some force, other parts of the system will push the object several feet away by a motor, and syncing two motors together would be a big hassle, even kicking off the stepper or DC motor will put too much drag on the system. At some point the object returns to within 2-3 inches of its original starting but, but needs some assistance getting back to zero.
You didn't say how fast you wanted to move 2-3 inches. Technically a motor is an electro-magnet.
And the pulling or pushing won't be on an incline of any kind? ..because pulling or pushing is a lot different than lifting.
Once the slide is moved over a few inches, another motor elsewhere in the system causes the slide to move much farther down, so the travel is not limited to 3 inches, only the "assistance area" the slide needs.
Dave
Is this an inertia issue with the drive motor? If you look at your system as a "T" where the drive motor is in the top of the "T" and the breakable panels are in the stem of the "T" do you have to go on both sides of the "T" to break the panels or could it be configured in an "L" using just one side of the "T"? The reason I ask if it's an inertia start/stop issue, then changing the angle of "L" slightly to make it acute (less than 90 Deg) might be enough to overcome the start /stop inertia when the panels need to be straight.
If that's not the case however, you have a greater moment arm from the 'breakable panels', meaning that you would need less force to move the panels then trying to move the drive motor. In this case a magnet mounted in each, or just a few 'breakable panels' that align with a coil(s) placed on the track might work. The size and number of windings would be subject to experiment, but if you wanted something that would not interfere with the track itself, I would maybe start with two smaller coils mounted on either side of the mechanical track or guide that are configured opposite polarity of one another and wired so that they would both come 'on' at the same time, so one would effectively push at the same time while one would effectively pull. All of the coils would be Air-core <- so when they released, there would not be a potential for the magnets in the panel to 'hold' a position under the coils.
@Beau
It is an "L", the motion perpendicular to the main drive belt and motion is only on one side. So the slide that I want to assist is only on the horizontal part of the L, only at the junction of the stem of the L. As far as inertia, it is not an inertia issue to break the panels, as the main drive cannot break the panels apart until the slide shown in the photo is first dislocated from it's Zero position. The same applies to returning the slide to Zero to park, the system mechanically is not capable of moving the slide back to home, so in neither case is it a matter of inertia moving the slide. I hope I answered what you were asking, I may not be completely clear though. It is not possible to allow an angle to exist to prevent the 'locking' of the system.
https://www.surpluscenter.com/item.asp?item=5-1707-R&catname=electric
https://www.surpluscenter.com/item.asp?item=5-1678&catname=electric
https://www.surpluscenter.com/item.asp?item=5-1752&catname=electric
