Magic IR
I am trying to use Gadget Gangster's Magic IR to trigger the play button on my Bose, but I keep getting a different set of values each time.
It works when I use the demo program, but when I try to feed magicir.playcode(4,play,127) from an array in DAT where I entered the values from the code1 array variable, it is a no go.
And each time I re-run the demo program and hit the play button I get different values for code1 and code1len.
I modified the original program to output the values for code1 and code1len.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
magicir : "magicir_010"
DEBUG : "Parallax Serial Terminal"
VAR
LONG code1[128], code1len, i,x
PUB main
magicir.storecode(0, @code1, @code1len)
DEBUG.start(250000)
waitcnt(clkfreq*8 + cnt)
x:=1
repeat i from 0 to code1len
x++
debug.dec(code1[i])
debug.str(string(" "))
if x == 11
debug.str(string(13))
debug.str(string("------------------------------------"))
x:=1
debug.dec(code1len)
repeat
'magiccir.playcode(4,play,127)
magicir.playcode(4,@code1,@code1len)
waitcnt(clkfreq*5 + cnt)
DAT
Play long 85958,200065,245599,359681,405554, 519313, 565188, 599137, 644670, 758433
long 804301, 918385, 963916, 997857, 1043729, 1077665, 1123207, 1157153, 1202692, 1236641
long 1282175, 1316113, 1361661, 1475761, 1521310, 1555265, 1600795, 1634737, 1680614, 1794369
long 1840238, 1954001, 1999870, 2113297, 2158834, 6188705, 6274315, 6388417, 6434295, 6548049
long 6593931, 6707697, 6753573, 6787521, 6833389, 6947137, 6993010, 7106769, 7152653, 7186593
long 7232141, 7266097, 7311625, 7345569, 7391111, 7425057, 7470942, 7504545, 7550428, 7664193
long 7710075, 7744017, 7789561, 7823505, 7869045, 7982817, 8028689, 8142785, 8188324, 8301745
long 8347626, 12378289, 12464245, 12578353, 12624230, 12738001, 12783867, 12897617, 12943481, 12977761
long 13022973, 13137073, 13182957, 13296721, 13342603, 13376545, 13422085, 13456033, 13501575, 13535521
long 13581061, 13615009, 13660551, 13694833, 13740041, 13854145, 13900033, 13933985, 13979525, 14013473
long 14059020, 14172785, 14218675, 14332449, 14378330, 14491425, 14537300, 18567169, 18652785, 18766897
long 18812778, 18926545, 18972427, 19086209, 19132090, 19166385, 19211590, 19325697, 19371577, 19485345
long 19531236, 19565185, 19610728, 19644673, 19690216, 19724497, 19769703, 19803985
Timing values will change slightly, too.
One thing that's odd is you have 127 transitions - although there's space for that many, the code shouldn't need 127 transitions.
Try re-recording the IR command, but this time just quickly press the button. Is the transition count shorter?
I rewrote the Parallax Serial Terminal output for an easier cut and paste.
The unlimited power your code provides is intoxicating. Oh, the possibilities.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ magicir : "magicir_010" DEBUG : "Parallax Serial Terminal" VAR LONG code1[128], code1len, i,x PUB main magicir.storecode(0, @code1, @code1len) DEBUG.start(250000) waitcnt(clkfreq*8 + cnt) x:=1 debug.str(string("Code1len is ")) debug.dec(code1len) debug.str(string(13)) debug.str(string("DAT")) debug.str(string(13)) debug.str(string(" Play long ")) repeat i from 0 to code1len x++ if x == 10 debug.dec(code1[i]) debug.str(string(13)) debug.str(string(" long ")) x:=1 else debug.dec(code1[i]) debug.str(string(",")) debug.str(string(13)) repeat 'magicir.playcode(4,@play,@playlen) magicir.playcode(4,@code1,@code1len) waitcnt(clkfreq*5 + cnt) DAT Volup long 85913,199949,245796,359837,405668,519373,565208,599133,644640 long 678893,724411,758333,803851,837773,883293,917213,963070,996989 long 1042509,1076445,1121951,1155869,1201382,1315405,1361250,1474941,1520782 long 1634813,1680656,1794349,1840196,1954205,2000058,2113069,2158917,6188605 long 6274514,6388525,6434381,6548077,6593917,6707949,6753788,6787709,6833231 long 6867165,6912672,6946941,6992447,7026381,7071887,7105821,7151325,7185245 long 7230763,7265021,7310540,7344461,7389979,7504013,7549859,7663549,7709401 long 7823437,7868945,7982989,8028832,8142525,8188371,8301725,8347565 VPlen long 70 Play long 85625,199733,245607,359381,405258,519029,564909,599189,644394 long 758501,804377,918149,964023,997973,1043509,1077461,1122995,1156949 long 1202482,1236773,1281970,1316245,1361453,1475557,1521431,1555381,1600928 long 1634869,1680419,1794197,1840071,1953845,1999716,2112805,2158685,6188325 long 6274284,6388373,6434254,6548005,6593876,6707637,6753518,6787797,6833010 long 6946789,6992659,7106421,7152298,7186581,7232118,7266069,7311605,7345557 long 7391100,7425045,7470589,7504869,7550068,7663829,7709712,7744005,7789202 long 7823477,7869027,7982805,8028675,8142437,8188314,8301413,8347283,12378245 long 12463869,12577957,12623836,12737589,12783800,12897573,12943442,12977397,13022931 long 13136693,13182567,13296341,13342214,13376165,13421695,13455973,13501179,13535461 long 13581002,13614949,13660481,13694421,13739962,13853733,13899605,13933557,13979095 long 14013381,14058578,14172341,14218553,14332325,14378202,14491301,14537170 Playlen long 106http://www.savagecircuits.com/forums/showthread.php?169-Networked-Universal-Remote
The Panasonic PNA4601M uses a 36.7 kHz carrier frequency while the Vishay TSOP4838 uses 38kHz.
Which frequency is used by most remotes?
A mouser part # would be helpful if you happen to know.
I just came across this page tonight. It has 3 different IR LED's. (Interesting)...
http://www.rentron.com/remote_control/IRLED.htm
Then see "The Transmitter" at the following link. This discusses IR LED's and so forth...
http://www.sbprojects.com/knowledge/ir/ir.htm
BILL190 - Thanks. That was very interesting reading !
This object:
-- http://obex.parallax.com/objects/462/
... will let you transmit serial using an IR LED. The receive end is a standard IR receiver module.
