Serial Break function for LIN bus?
I'm using FullDuplexSerial to talk to an automotive LIN bus which needs a Break function (pull the serial line low for nn bit times where nn>=13). How can I add this function to FDS, or is there a different serial driver I should use? (New to SPIN, & haven't used assembler since the 70's!)
-Gary
