Data Tables
First Post. First Propeller program. Hopefully I got the correct forum. So..here goes...
Our company purchased and is using Propeller Tool for programming of a monitoring board we have developed, called AIU. The AIU program uses a couple of DAT tables to set array values that the program acts upon. These values need to be changed depending on the site we are installing our monitoring system. I would prefer not to give our source code to our technicians, but they need to be able to alter the table as needed. I would rather have a PC GUI based program prompt the technician for the desired values and have that program, using the USB interface, download the new values into the EProm at the correct location.
Here is the data data.
DAT
Active Byte 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0 '1 for Active Alarm and 0 for non active
AlmState Byte 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0 '1 if state of alarm is high, 0 if low
AlmOut Byte 1, 2, 2, 2, 3, 3, 3, 4, 4, 4, 15, 15, 15, 15, 15, 15, 15, 15 'Sets the pattern for the output relays
AlmDel Byte 1, 1, 1, 1, 10, 1, 10, 10, 10, 10, 0, 0, 0, 0, 0, 0, 0, 0 'Sets a time delay before the alarm sets
What are the options to accomplish this?
Sample code anywhere posted?
I can easily create a comma delimited table on the PC, but how would I read it in and commit it to the proper memory location of the Eprom?
How would I control the address of where the DAT tables reside? We are using a 24LC256 Motorola Eprom.
Looking forward to some help.
Thank you,
Rob Sobol
RSobol@HilightsInc.Com
DAT
Thank you,
Rob Sobol
The downside of this method is that the location of the data in the binary file will change each time you modify other aspects of the program.
You'd have to use some kind of custom program on the PC side or maybe just a serial terminal emulator depending on how sophisticated your technicians are.
My short fix is going to be having the techs use a spreadsheet that will output a syntax correct file that the compiler can Include in the source code. This might keep them from messing with the source code if all they have to do is edit the spreadsheet, save the file, load the compiler and source code, connect the cable and press F11.
Wish the compiler had a Command Line Option, I would have the spread sheet invoke the compiler and do the F11 thing.
In the mean time I welcome more suggestions.
Thank you for your thoughts.
Rob
Thank you for your patience with these Neanderthal questions from this new user.
I wasn't sure just how insulated from the source you wanted to keep the techs. When advocating the binary approach, I was assuming the max, i.e. that the source would be locked away somewhere completely inaccessible.
If that's not the case, take a look at the FILE pragma in the Spin manual. It allows you to put a data table in a completely separate file from the rest of your source code. Your GUI front-end could then populate that file and invoke Propellent to re-upload the entire program.
Unfortunately, this pragma is very poorly documented in the manual. Left to the reader's imagination are such important details such as the data types (BYTE, WORD, LONG) that can be imported, the file's syntax, and whether labels in the file are incorporated into the source code.
If the pragma's limitations turn out to be an issue, you could also jsut put the DAT table in a separate object with a PUBlic method that reutrns its address.
DAT
File "RelayTable"
And the contents of RelayTable are as follows:
and I get 'unexpected variable' error message as soon as the compiler tries to reference
byte[@AlmState][index]
and the quick fix is????
The file included with the "file" statement is not more Spin code or data definitions that is compiled with the Spin tool. It is just the binary content of the file. A "binary blob" of whatever data that file contains. Therefore whilst you have included the text of your file into the Spin the labels "AlmState" are not recognized by the compiler.
The "syntax" or layout of the data in your file is entirely up to you and you must write Spin code to handle it.
The simplest case is just to create a file containing all your byte parameters as actual 8 bit binary values and the access those parameters as an array.
As Phil points out the "file" statement just includes a bunch of bytes into your DAT section. Problem is the data type is undefined so when your access data you may not get what you think.
If you have:
What doe this do in Spin?
I deal with this by using file in the following way:
Then use the "parameters" label to access the content.
something := parameters[4]
Of course one can use WORD or LONG as the type of parameters instead.
If you change the content of the RelayTable file to just the binary data:
1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0 ....
then you can do something like that:
The .bin files apparently have to be packed binary -- not comma-separated values.
Still, you might want to treat that data as an array of LONGs (or WORDs) as so:
Prints the LONG from byte offset 8 in the data rather from offset 2.
Now I just have to remember why I felt the need to force the type to BYTE for the bytecodes in my Zog interpreter and for the Z80 opcodes in ZiCog before that.
If you need to modify the table simply plug it on the PC and copy your new table file to the card.
There is a lot of SD stuff, a regexp object and a lot of other stuff.
You could make the propeller update its eeprom table, or simply read it every time, it depends on your needs.
In theory if you go for high volumes you could also contact Parallax and have a code protected solution.
Massimo
