Propeller Counter question
K2
                    When using one of the Prop's counters in Duty Cycle mode, is there any way for PHSx to be automatically preloaded with a new value when APIN goes high?  Lacking that, is there a way to automatically preload FRQx on a counter event?
What I'm trying to avoid is the indeterminacy involved whenever program control is used to sense a condition and modify a register.
Maybe the key to avoiding indeterminacy is to update PHSx under program control just after an overflow or underflow event? But can a read/modify/write be done to PHSx without slipping or skipping a few clocks? AN001 seems awfully scarce on practical details. And none of the coding examples shown seem anywhere close to a real-world application.
On the other hand, there is a comment line in one piece of code that says:
That sort of wording gives me hope that there's more to the counters than I've discovered so far.
'back up phsa so that it trips "value" cycles from now.
No. APIN in DUTY mode is an output, anyway.
No.
No. You can't perform a R/M/W operation on the PHSx register of a running clock.
What is your overall objective? Perhaps there's another way to achieve it.
Naturally APIN is an output. But ever since Adam and Eve, outputs have been connected to inputs in order to trigger events.
I'd like to create an arbitrary squarewave with 12.5 ns timing resolution and no jitter.
From 2500 Hz to 5000 Hz. I'd also hoped to be able to smoothly vary the frequency, in one Hertz increments, on the fly. It would seem that I ignorantly imbued the Prop counter with capabilities it never posessed.
"One of my wishes for the Propeller II is a timer mode that allows one to create a set-and-forget PWM signal with a fixed frequency, variable duty cycle. It would be nice to load on-cycles and off-cycles into registers and just let it fly (like one of the modes of the SX48 counter/timer)."
I very much agree, JonnyMac. Beau has suggested that the new I/O pads contain fabulous new features. Hopefully they include exactly what you describe.
Meanwhile, I'll probably continue doing just as I have done up to this point in the design - use SX chips.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OUTPIN = 6 VAR long Period PUB start set_period(300) cognew(@squarewave, @Period) PUB set_period(pd) Period := (pd >> 1) - 12 DAT squarewave mov ctra,ctra0 mov frqa,frqa0 mov dira,dira0 sqlp rdlong per,par waitpne zero,dira0 or per,sign mov phsa,per waitpeq zero,dira0 andn per,sign mov phsa,per jmp #sqlp ctra0 long %00100 << 26 | OUTPIN frqa0 long -1 dira0 long 1 << OUTPIN zero long 0 sign long $8000_0000 per res 1-Phil
How does the divide-by-four nature of the cog clock not interfere with the accuracy of waitpeq and waitpne? I'm guessing that for any particular cog on any particular day, the same number of system clocks (0, 1, 2, or 3) expire before that cog sees the respective condition met and resumes exection.
Anyway, it's a great lesson for a newbie on how to get accurate timing done on a Prop. Thanks again!
Yes, that's to accommodate the overhead between the waits and the moves to phsa.
The wait instructions have a granularity of one clock for the time that they resume execution once their conditions are met.
You're welcome!
For single output, Phil's program may be modified to do what we need. And dual output using the counters in the way he did would also be easy enough.
The first thing I realized, once I understood Phil's code, was that his approach could easily be extended to two counters to generate two non-overlapping variable-frequency variable-duty-cycle PWM outputs.
Once I added two resistors, a film capacitor, and two 4th-order switched-capacitor filters, the project was done!
My employer has spent a small fortune on development tools from company A (of the great State of Massachusetts).
For pennies I'm getting the same results with an insanely simple set-up, free tools, and a Prop. I'm putting together a show-and-tell for the big boss. My hope is that it will restore sanity here, and sell a few Props in the process.
For textbook timing we'd expect -6 in temp. With the 0/4+ combination mentioned above I get -7 on the demo board due to internal delays. Picking an example, I measured the time between two low/high transitions from within a different cog (waitpxx/cnt). With a set period of 532 I get 532 for 0/2 but 534 for 0/4+ (that's running the PASM fragment you posted unchanged).
That said, it's only likely to be an issue (in terms of accuracy) when you get close to 1MHz. Everyone relax!
Suggested fix:
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OUTPIN = 0 VAR long Period PUB start set_period(300) cognew(@squarewave, @Period) PUB set_period(pd) Period := [COLOR="Red"](pd >> 1) - 6 | $80000000[/COLOR] DAT org 0 squarewave mov dira, dira0 mov ctra, ctra0 neg frqa, #1 sqlp rdlong per, par waitpeq dira0, dira0 [COLOR="Red"]mov phsa, phsa[/COLOR] [COLOR="Red"]add phsa, per[/COLOR] waitpne dira0, dira0 [COLOR="Red"]mov phsa, phsa[/COLOR] [COLOR="Red"]add phsa, per[/COLOR] jmp #sqlp ctra0 long %0_00100_000 << 23 | OUTPIN dira0 long |< OUTPIN per res 1 fitIt will take some time to digest the nuances you've incorporated. But I can already tell there is real cleverness to it.
I think it was heater who mentioned a while ago that the book is still being written on the Prop. I questioned that, privately. But I see that it is true, both with what Phil has done and with what you have added. Nice job!
What is it that causes the delay ? Is it the output to the pin ? The input from the pin ?
I'm just trying to understand why it makes a difference.
Bean
I think I get the internal delay part, although I'm surprised it amounts to an entire clock cycle. And I can understand how adding to phsa rather than just setting phsa each time fixes the problem. What I'm not sure I grasp yet (prior to my morning coffee) is how you get by with a read-modify-write to phsa when the counter is running. The operation is apparently primed by the mov phsa,phsa above it and must have something to do with phsa's shadow register, but I don't yet get what's happening internally, since both the counter and the ALU are contending to add something to phsa in the same machine cycle.
Can you explain? Whatever the explanation, though, it's a neat trick worth remembering! Up until now, I've been using the textbook approach of jiggering frqa to effect a phase shift. But that's limited to multiple-of-four-clock shifts.
Phil:
Would this be suitable to use as a clock input to other propellers? The idea being this would run on prop, and it's output would be sent to other propeller's to keep them all 100% synchronized? All of the props that have their clock's use the output from this would be synchronized with that counter.
KK
I suppose it could if you used Kuroneko's modification and were satisfied with no more than 1MHz. It would be much easier, though, just to set one of the counters to a "pure" (i.e. power-of-two) frequency and use that.
Thanks Phil.
I got the notion some time ago that doing that wouldn't work. Not sure why, but I just got that idea. Anyway, if what your saying is true, then I can in theory drive a series of props to their max speed with only a few passives to provide for the interconnect. is that about right? I haven't experimented with it yet, but the notion to try something likes this is sitting RIGHT there...
IMO the output delay (OR chain) plays a major part in this. I mean, there isn't anything else in the way and this particular pin is not connected to anything on a demo board. Also, the fact that it affects cog IDs 4+ suggests that distance is involved. OTOH, the pins have to go back to the cogs to be sampled which may have some influence as well.
You got me there. In the [thread=118096]Clarity thread[/thread] output propagation and setup time are given with ~2ns so at 80MHz that's still 8.5ns left for not being missed. Most odd. A bit like generating 40MHz with a counter and a waitpxx not seeing it. HA!
No magic involved this time. When data is written to phsx shadow and counter are updated. So the initial mov phsa, phsa will primarily update the shadow register and cause the counter to stutter slightly (it keeps counting but is set back 2 cycles when the result is written) but that's not important in this context. The next op is read-modify-write (add phsa, per). With phsx being special (in the destination slot) the actual op performed is:
Our last written value originates from the mov (textbook: -6/POSX-5). We add the period and write it back, affecting both shadow and counter (Any instruction writing to PHS will override any accumulation for that clock cycle.). HTH
This made me laugh. It wasn't until I reread your post #17 carefully that I even understood the questions.
Reading both the questions and answers a few times, though, has finally brought a measure of clarity.
FWIW, because I was using cogs 0,1, I hadn't noticed the slightest timing discrepancy. In fact, commenting out the rdlong, the code does a nice job of generating square waves nearly to 3 MHz. There is also an easy way to control both frequency and duty cycle with just one counter. Toggling DIRA rather than OUTA, and using switched-capacitor filters, one can obtain a nice sine wave with wide-ranging amplitude control. Just what the doctor ordered. Literally.
Below is the timing for cogs 6/7 using the outa approach (pins 0/24).
Now back to using counters. We let an NCO drive that particular pin in cog 6 and use the same receiver code in cog 7.
The delays for pin 0 and 24 are 5 and 4 respectively (they are not 4 and 3 due to the extra delay of getting frqa set and being used for increments, R:set, S:use). This would suggest that it's not the OR chainA which causes the missing cycle as indicated earlier but something based on how the counter outputs are connected to the I/O pins.
Using cogs 0/1 reverses the counter timing, 5 cycles for a round trip to pin 24 and 4 to pin 0. Note that the delay is defined by the sender cog and the link pin, i.e. sending from cog 0 to pin 24 and receiving in cog 7 is slow whereas using pin 0 doesn't show any delay (cog 0 >> pin 0 >> cog 7).
Anyway, maybe a waitcnt based version would have been better in the first place? It certainly avoids all the subtle cycle adjustments.
CON _clkmode = XTAL1 + PLL16X _xinfreq = 5_000_000 OUTPIN = 16 VAR long period PUB start set_period(clkfreq) cognew(@squarewave, @period) PUB set_period(pd) period := pd >> 1 DAT org 0 ' waitcnt version squarewave mov dira, mask ' -4 mov outa, mask ' +0 = mov cnt, cnt ' +4 add cnt, #9 + 12 ' +8 sqlp rdlong hper, par ' -4 waitcnt cnt, hper or outa, mask waitcnt cnt, hper andn outa, mask jmp #sqlp mask long |< OUTPIN hper res 1 fitA it contributes to the delay but not significantly
You're a bulldog! I'm sure all of us appreciate your grit and determination to get to the bottom of this! It might be time for Chip to look at the schematic again.
Check out my link, i do that with my program and schematic.
http://forums.parallax.com/showthread.php?t=124343
It would be nice to be able to see the innards of the various prop chips when it comes to their cog and I/O pad + pathway. I have found some intense die images of the prop, but never shown with cog numbering, pin labels and pathways...
