Resistors (SMT) for Prop (LQFP)
MacTuxLin
Hi,
May I know if the following SMT spec for those 10k resistors used by 24LC512 & uSD sockets is appropriate or is there something I should be looking out for?
Power Watt: 1/4W
Tolerance: 1%
Description: RES 10.0K OHM 1/4W 1% 0805 SMD
Thanks in advance.
Power Watt: 1/4W
Tolerance: 1%
Thanks in advance.
0805 is a dimension easy to hand solder. Being pull up resistors you have no power or tolerance issues.
Note: If you think of using arrays you must be careful, some are not easy to solder.
The mouser PN 774-743C043103JP is ok for me..
Massimo
