Propeller-based Lighting Control System
Hi, I'm totally new to the propeller platform, I've previously used Arduino boards and became interested in the propeller for the simultaneous processing.
I'm working on a final-year school project, a control desk for lighting systems, see here and here for the sort of thing I'm thinking of.
These devices have very simple video displays (using monospace characters), up to a couple of hundred input buttons or potentiometers, LEDs for feedback and usually some further auxiliary displays (which may be as simple as an LED matrix).
I've (nearly) successfully made an Arduino-based 8-channel light controller by reading potentiometer values, mapping them to within the range of the master potentiometer, mapping that to within the range of the DMX protocol (0-255), which is the most popular lighting control protocol currently used. If you're unfamiliar with it, there's a good explanation here. The protocol is based on RS-485 and as such msot projects use a Maxim MAX485 Chip to send DMX data (I'm using this chip with the Arduino). So far, the output of the Arduino should be working, but causes the light it's hooked up to to flicker. I'm planning on buying a digital oscilloscope to find out what's going wrong.
My current idea of how to use the propeller would be to use one cog to scan inputs for changes and trigger the appropriate response on other cogs, have another cog constantly transmitting DMX data from some kind of shared memory that other cogs can update. The remaining 6 cogs would handle events and video display.
As I said, I'm unfamiliar with the platform so I don't know how much of this is practical or whether it's the most sensible way to do it.
Any constructive comments are very welcome.
Thanks, Michael
Thanks, Michael
For the software, you can take a look at Jon Williams' Spin zone column on DMX (here, pdf). There's also sample code here.
I'm pretty sure his code only uses one cog for the DMX portion, that gives you plenty of horsepower for the rest of your project.
I noticed that the code reads the dmx into a buffer... I'm hoping to do this with analog inputs and for the dmx output. What would be the best way to store 512 8-bit integers, in order, on the propeller? It would need to be accessible to all cogs.
M
If you use my DMX transmitter object (jm_dmxout.spin) then the 512-byte buffer is built right in and you don't have to worry about creating your own buffer. You can read a pot or some other input, massage it as desired, and then write it to the buffer for the channel you want (using the .write() method). If the DMX output has been enabled it will be broadcast in the next cycle.
Since you desire multi-cog access you would want to use the .address() method which provides the hub location of the buffer. You can use this to provide access (read or write) from any cog.
BTW... I am Iron Man Jon Williams
M
If you're want a PASM cog to read from or write to the DMX buffer then you will need to pass the address of the buffer to that cog.
I had...
2 x input scanning cogs
1 x DMX output cog
2 x video driver cogs
1 x video display cog
2 x DMX 'engine' cogs
The 'engine' cogs took data from the input buffers and filled the output buffers.
The 'display' cog took data from the input and output buffers and formatted them for display.
For fun I wrote my own DMX output routine which generates 8 DMX streams in a single COG.
M
That's kind of what my 'engines' did. The 'beauty' of DMX is that you always know what you are going to do next, ie either the next output or the start of a new frame, as so you can easily interleave operations. For instance, if you didn't want a VGA display you could take those cogs and use then as engines, interleaving them 4 ways.
In fact my ultimate plan was to split the whole thing across 2 propellers with one handling the user interface and one doing the hard work using 1 cog as input from the UI, 6 cogs running as engines and the last cog outputting 8 DMX streams.
My prototype...
1st cycle...
Engine 1 is transferring the result of its work to the output buffer position for DMX slot 1 while engine 2 is working on the second half of DMX slot 2 while engine 3 is working on the first half of slot 3 and engine 4 is collecting data from the inputs to work on slot 4.
Next cycle...
Engine 2 is transferring the result of its work to the output buffer position for DMX slot 2 while engine 3 is working on the second half of DMX slot 3 while engine 4 is working on the first half of slot 4 and engine 1 is collecting data from the inputs to work on slot 5.
So engine 1 works on slots 1,5,9,13...; engine 2 on slots 2,6,10,14.... etc etc
