Plate your own holes thru.
Martin Hodge
Interested in making "professional" plated-through-hole prototypes yourself? Have WAY too much time on your hands? MG chemicals has the solution for you.
http://www.mgchemicals.com/techsupport/proto_prof.html
It also brought up another thought. I wonder how much copper you could deposit using the process for plating a telescope mirror. Basically, you put the mirror in a chamber, draw a vacuum, and then run enough current through a small piece of aluminum (or other material, like gold, depending on the wavelength of light you're after), and the metal condenses very evenly on the surface of the mirror (and the inside of the chamber, and anything else in it).
Normally this coating is VERY thin, but I'm wondering if it would be possible to machine a blank board (no copper) with the holes and vias, and deposit enough copper to make a usable circuit board. You might even be able to do something so that the copper wouldn't stick to the areas you didn't want traces, and then you wouldn't need to etch afterwords.
Probably not very practicable, but I just thought I would throw that out there.
John R.
http://www.pulsarprofx.com/pcbfx/main_site/pages/tech_support/plated_thru_holes/plated-thru_holes.html
In Taiwan, it seems that every years someone feels the need to seek fame by writing a Chinese poem, the Lord's Prayer, or some other text on a grain of rice.
Why I don't know.
One can make a two sided board without plated through holes. Plated through holes tends to only be required when you have blind vias to layers that are internal.
I suppose we could make our own capacitors and resistors as well................... NOT!
