Need help with first SX/B program
TC
I am working on a small project that uses a dot matrix name tag with the microprocessor removed, and I am trying to learn how to program the SX. I have done some PBASIC programming, so I am using SX/B. I am getting a little stuck. I am making a 12 hour clock that will use a DS1302 to keep track of the time; right now I am trying to control the display. I have a somewhat working test program that counts from 0 to 9. But I cannot figure out what would be the best way to display the clock info. I took a shot at it but I am running out of space (I think).
Could someone please take a look at my code and give me some ideas or pointers on how I can make this program work. Now I dont want anyone doing the work (that is my job) so if you can explain what I should do, I would be a happier person.
I have included my working test program name_tag.SXB
And I have included my problem program Clock.SXB
Thank you for any input.
It looks like you are not declaring your SUBs and FUNCs in the beginning of the program.
That should take care of the errors.
Bean
A subroutine doesn't return any values. A function does (though it doesnt have to).
Hope that helps
