Simple audio amplifier
Hello Everyone,
It might seems like a silly question but...I would like to have a small audio amplifier connected to the proto propeller board. The demo board has a MAX4411 (and uses only PIN 10 and 11) that I can't find around...Does anyone have a suggestion?
I just need to play basic sounds, nothing fancy. The demo board does the trick but I need to have a proto board for my live project so I can use the demo board for the development.
Thanks!
Tex
Thanks!
Tex
For R1 try something like 1K, for C1 try 10nF or 100nF, C2 try 1uF to 10uF (if electrolytic then + to R1C1 junction. You can get a non-polorised 1uF mono.
Someone like Phil or Andy may be able to give you better values as I have not tried these, but you will not hurt the prop nor the amp with these values.
