Tiny Tester for Developing Parallel Algorithms — Parallax Forums
HumanoidoHumanoido Posts: 5,770
edited 2010-10-14 01:42 in Robotics
AM - Algorithm Machine
A Tiny Tester for Developing Parallel Algorithms
You can use this tiny tester, built from Parallax parts, for developing parallel algorithms and running tests for much larger machines (including large Propeller based parallel cluster machines under design and construction). It's a real time saver! The tester is an upgrade and a spin-off of the Minuscule BASIC Stamp Super Computing Machine.
This is a tiny algorithm machine, simple to build, easy to use. The field of parallel clustering computing is relatively new to hobbyists. Developing techniques and methods is an important aspect of cluster computing to gain the greatest rewards and benefits from not only paralleled space but multiprocessors as well.
Features
  • Operates in five BUS modes
  • Serial & Parallel options
  • Includes WIDE BUS
  • Handles up to 200 step code
  • Programs in PBASIC
  • Very small footprint
  • Builds with Parallax BASIC Stamp 1 Project Boards #27110
  • Speakers & LEDs for output
  • Twin 9-volt battery operated
Use the above schematic to build the tester, then program it with
parallel algorithms to test various interfaces and parallel configs.
Provisions are made for converting between single wire, full duplex,
and data buss interfaces.
Information
For more information refer to the signature.
Overview
It doesn't matter if you're using stamps or props, parallel techniques work cross platform. Here's a chance to use a language that's been proven over time and develop routines for new parallel machines. The addition of the upgraded interface bus allows for trying out several hardware configurations such a one wire, serial full duplex, and data bus.
Criteria
The AM is currently being used with the UltraSpark 40 Supermicrocontroller Parallel Computing Machine and satisfies several conditions for testing the new series.
Interface
This versatile machine operates in four modes, which can be wired as single mode A, single mode B, or dual modes A & B, or simply C mode. Operate the AM using a single wire and serial PBASIC code commands or program the machine using the seven parallel port bits.
A - Single Wire Serial P0
B - Parallel Bus P3, P4, P5, P6, P7
A + B Dual BUS, as seen above
C - Parallel Bus Only P0, P3. P4, P5, P6, P7
Code and Parallel Algorithms
It is left up to the user to derive various parallel algorithms in PBASIC
code. However, as code becomes available, it can be posted in this thread.
The 1st proposal is a split function task for n processors. In this example,
one program is written that supplants itself into n processors and auto
determines the work share for each processor. Time passes and the work
conclusion is collected and concluded. It is ok to create a separate
collection program.
Humanoido
    edited 2010-10-11 23:15
    Update 10.12.2010
    This update includes the name AM - Algorithm Machine. This is a tiny minimal two core machine capable of quickly running tests on simple parallel algorithms. The second advantage of the machine is that it introduces a new wide bus for experimentation.
    edited 2010-10-12 11:20
    Update 10.13.10
    Revised Draft Schematic Posted
    640 x 404 - 59K
    edited 2010-10-13 00:56
    Introducing WIDE BUS
    D - P0 - P7
    Regarding bus modes. For a D mode, WIDE BUS, remove the LEDs and Peizo speakers to gain a parallel eight bit BYTE bus data array using pins P0- P7. Connect, P0 to P0, P1 to P1, P2 to P2 up to P7 to P7, confirming a protection resistor (220 ohm) across each port.
    edited 2010-10-13 00:57
    BASIC Stamp 1 Project Board Schematic - Use for Wiring the AM
    Schematics may be difficult to find these days. Use this BS1 Project Board schematic when wiring two boards together to create the AM project.
    The 93LC56 chip is an EEPROM with 256 bytes size or 1/4th K. This holds up to 100 instructions. The microcontroller is a Microchip PIC16C56A running at 4MHz. This gives about 2,000 IPS Instructions Per Second. The serial PC interface runs at 4,800 BAUD for programming and debug. Power can be within the range of 6 to 15 volts.
    Source / Sink Current per I/O.................. 20 mA / 25 mA
    Source / Sink Current (device) ................ 40 mA / 50 mA
    Power Consumption................................ 7 mA running (no loads); 5 mA Sleep (Rev B)
    On Rev B boards the power LED remains illuminated when the BASIC Stamp is in sleep mode
    839 x 633 - 280K
    Use these Commands for Programming
    BRANCH Branch to address specified by offset
    BUTTON Monitor and manage button input; branch if button is in target state
    DEBUG Send variables and/or messages to PC for viewing
    EEPROM Store user data in available EEPROM space
    END Terminate program and enter low-power mode until reset
    FOR...NEXT Create numerically controlled loop
    GOSUB Unconditional branch to a subroutine
    GOTO Unconditional branch to program address
    HIGH Make pin an output high
    IF...THEN Compare and conditionally branch to program address
    INPUT Make pin an input
    LET Optional designator for assignments
    LOOKDOWN Search for target in table; if found set output variable to target location
    LOOKUP Set output variable to table data specified by offset
    LOW Make pin output low
    NAP Enter low-power mode for short period
    OUTPUT Make pin an output
    PAUSE Suspend program for 1 to 65,535 milliseconds
    POT Read a 5 – 50 K variable resistance and scale result
    PULSIN Measure width of an input pulse
    PULSOUT Output timed pulse by inverting pin for some time
    PWM Output analog level (requires external RC network for filtering)
    RANDOM Generate a pseudo-random number
    READ Read byte from EEPROM location
    RETURN Return from a subroutine
    REVERSE Reverse pin state; make input if was output, output if was input
    SERIN Receive serial data, 300 – 2400 baud, N81 format
    SEROUT Transmit serial data, 300 – 2400 baud, N81 format
    SLEEP Enter low-power mode for 1 – 65,535 seconds
    SOUND Generate tone or white noise
    TOGGLE Make pin an output and toggle current state
    WRITE Write byte to EEPROM location
    edited 2010-10-13 02:28
    More Photos
    This view of AM - Algorithm Machine, shows a nearly cubical shape, wired in WIDE BUS mode. The solderless breadboard is used only on the top board. Wiring is made with the pin connectors. The bread- board is used for adding the Peizo speaker and LED outputs in other modes.
    625 x 473 - 39K
    edited 2010-10-13 03:07
    reserved for project
    edited 2010-10-13 04:05
    Reserved for AM identifications
    edited 2010-10-13 04:06
    Reserved for AM SO and data
    edited 2010-10-13 21:33
    AM Algorithm Machine BS1-IC Experiment
    Instead of using two Stamp 1 Project Boards, this experiment uses a BS1-IC in SIP form. A BS1 module (Parallax part number BS1-IC) plugs into the solderless breadboard on one Stamp 1 Project Board and extends its buss connections directly to the board. The following features result.
    • Significantly Smaller
    • Improves Wiring Efficiency
    • Better Visibility
    • Maintains both Peizo & LED Outputs
    • Requires Only One Battery for Field Use
    • Rewiring is faster
    Basic Stamp 1 Module
    http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/CategoryID/9/List/0/SortField/0/Level/a/ProductID/3/Default.aspx
    Boards setup before wiring. This setup uses a Revision B Project Board and a Revision C BS1-IC. The Project Board programs with a serial to USB converter and has a choice of batter or power supply operation. The on/off switch is especially handy for recycling power.
    default.aspx?f=5&m=342718attachment.php?attachmentid=74433&stc=1&d=1287034197
    Schematic for rev. c was not found, however, the pinout of BS1-IC Rev. B can also be used for wiring Rev. C.
    Note, this experiment is provided for pure academics. In actuality, to program the add-on BS1-IC SIP, add a small three pin programming port and a Parallax Serial Converter, then connect to the PC.
    557 x 495 - 240K
    558 x 265 - 102K
    Reserved for coding, code examples, users input, samples, and demos..
