Can't Get SB/X to Open Old File
I have moved to using a new computer. When I try to open my old SB/X .sbx files I get a black box that flashes on the screen and then it disappears. SB/X does not come on.
marshall edgell
marshall edgell
Did you try right clicking on the *.sbx file, and click the open with
When you moved to a new computer did you just copy the SX Key software or did you re-install SX Key software and the SX/B compiler? If so did you install the latest version?
Can you start SX/B and try creating a blank program from one of the examples in the help file to see if SX/B is working?
The .SXB file should just be an ASCII file and you should be able to view it in NOTEPAD or WORDPAD to see if the file at least looks ok.
Did you move to a new computer for more speed or because the old system was trashed by a virus, etc? If there was a virus it may have trashed some of your files.
Robert
Right clicking on an .sbx example file gives a black box that looks like its getting code but it vanishes within a few seconds.
marshall
What OS do you have, in win, right clicking on a file gives you a menu.
Are these really, or should they be, ".sxb" files?
It is all pretty straight forward, but you have to start by locating a Help Screen for file extension assignments in order find out what is where on the new OS.
marshall
