New design has bad voltage.
Paul
I just built a new Prop design using a LQFP package and the 3.3v LM2937 regulator is putting out 4.6v. (+5V in) This is probably my fifth LQFP design and I've never had problems with them before.
So far I have replaced the regulator, the capacitors on both the regulator's input and output, and the Propeller chip. Without the Propeller I have VDD = 3.3v.
Watching on a scope I found I get 3.3v until the EEPROM is read then VDD jumps up to 4.6v. Also I never see anything on the Xtal leads. I haven't been able to program it so all I/O should be floating.
Unless someone has ran into this before I'm at the toss it and start over stage I think. Any ideas?
Paul
Paul
My guess would be that you're trying to draw too much current through the regulator... Perhaps you have something shorted to ground somewhere...
Robert
GUESS #1: You have 5V levels running into an input somewhere. This finds it's way through the substrate and onto VDD pulling it up and the regulator is not designed to pull down a voltage so it sits there at 4.6V.
If you have 5V inputs then you must not only current limit them but you must make sure they do not affect VDD. You could try a zener but at those low voltages they aren't much chop. I use 2 red leds in series with a 47R across VDD and GND to help shunt those stray currents. When the Propeller is drawing more power then that excess current is soaked up (technical term) but when it sits back and idles you see the voltage shoot up.
Quote "any ideas?"
SUGGESTION: Show us your circuit
1) On a new design the first thing we do is install the regulator(s) and check for the right voltages at the pads. If the regulator is not 'loaded', it will float up to the supply level. Where are you checking our voltage and have you done continuity checks to the pads on the prop?
2) The regulator has a different pinout than assumed in the design they will behave like this.
Looks like I have a short under some component somewhere. Time to drag out the SMD rework station. Now where'd I put that manual?
Thanks forum, I appreciate the help.
Paul
The problem was (drum roll) I designed for a MAX232 and put in a MAX3232 instead. The 5V must have been feeding into the Propeller pins and screwing things up. I should have known better.
Paul
I'm glad you found the problem and thanks for posting the resolution. I've been using the MAX3232 with all my Propeller projects since it runs off the 3.3V supply. Just makes things easier to deal with.
Robert
