altoid prop
I travel a lot, so I carry a propeller (propstick USB) in an altoids tin, powered by the USB. The prime objectives were size, weight, robustness and flexibility. I toss it into my travel bag and it is well protected and doesn't take up any space. Female headers allow me to plug in whatever peripherals I want to for testing etc on the road.
Just wondering if anyone else has something similar to share. I might have to retire it when the C3 hits the street.
cheers,
Mark
cheers,
Mark
Doing some hobby-projects during your travels?
It is a clone of a DemoBoard basically, I put jumpers in to select/deselect the periferals although the A/D (sigma) proved to be a bit of a nuisence. The wiring proved to be less of a problem than I feared, I even had it running as a cut down DracBoard (64KB) with the memory and latches up on the breadboard, even with 6" long jumpers everywhere.
Jim
It was a Betacam SP tape box (small).
If the altoid version is intended for travel, what do the airlines think of a metal box with wires coming out of it?
Nice idea! Can you post the circuit you use to power the prop via USB? Does one USB port give you enough power?
It looks simple enough so even I would probably be able to build it!
Ross.
Edit: the prop uses 3.3volts so make sure to have a 3.3 volt regulator between the usb port and the prop if your not using the demoboard.
How do you protect your project from conductivity with the Altoids can?
I went to a baseball game in New York and security was using those wands. I pretty much have to take my keys, wallet, cellphone and everything else out of my pockets. I'm not sure what effect wands will have on thumbdrives... Better use dropbox and an internet connection...
Ross.
@Chuckz: I cut the lid of a plastic margarine tub to fit inside the altoid can to insulate the bottom of the cct board from the can
cheers,
Mark
All the spec's you need as well as diagrams are in this link
USB Spec's: http://en.wikipedia.org/wiki/Universal_Serial_Bus
Electrical 5 volt DC
Max. voltage 5 volts
Max. current 500-900 mA @ 5V (depending on version)
Data signal Packet data, defined by specifications
Width 1 bit
Bandwidth 1.5-625 MB/s
Max. devices 127
Protocol Serial
Cable 4 wires
Pins 4 (1 supply, 2 data, 1 ground)
Ross.
MG117
Here in Finland the famous L
Leon, thanks for the tip! I have a few different Altoids tins in the project box queue and clean holes without deformation was a concern. I have a few Altoid Smalls tins that I can squeeze in two AAA batteries and one of my M44D40+ modules into. They will be something eventually.......
