Amazon Kindle Feedback with PDFs??
WBA Consulting
Anyone have or know of someone with an Amazon Kindle that uses it to view technical PDFs (like datasheets)? I am looking for feedback as I am considering purchasing the Wi-Fi Only version for $139 for a PDF tool at work.
thanks in advance!
thanks in advance!
Apple is the one that shut out Adobe. I really don't know about Kindle, but I use a netbook specifically because most of my reading is PDFs and I am not really into reading recreation-ally on a screen. In the past I tried E-Books for a Palm PDA and then I tried E-books on the netbook.
Neither appealed to me, but I certainly don't want to print out something like a copy of the Propeller Manual when it may undergo a revision soon after I print and bound a copy. That is the case with most computer documentation - it is a waste of trees to print out published material that is somewhat evolving. And often the printouts remove color, which is quite a useful tool.
It would seem that Google would easily tell you in Kindle supports Adobe's PDF reader.
I just brought up the Propeller manual from the Parallax website on my browser, and at the same time, brought up the manual on my Kindle. The text is perfectly readeable, even though it doesn't fit the screen particularly well. The table of contents, for example, looks like
NEG.........................
..............................320
NEGC......................
..........................321
and so on; readeable but ugly.
The worst part is that many of the diagrams are simply missing. The 40 pin and 44 pin package pinout diagram, the cog "Block Diagram" and the "Hardware Connections" diagrams are just not there in the Kindle version of the Prop manual PDF.
Then I pulled up a Sandisk SD product manual. It's actually pretty good, and does contain some diagrams that converted very nicely into Kindle format.
So I would say that PDFs on the Kindle are generally useable but not great.
The Kindle has some features like high-lighting text, and making notes. But, that only works on Kindle format stuff. You can have personal PDF documents converted to Kindle format documents, which then you can use the high-lighting, and note making features.
I almost bought an Apple iPad, but I am so glad that I did not make that mistake. As far as I am concerned, this is the best reader out there.
Ray
John Abshier
The one thing that you do not get with the DX model is Wi-Fi, it comes with free G3, which I keep turned off to save on battery life. I only use it when I am to lazy to connect up to the computer to transfer some books. I just bought a book via the Kindle, and it was a very smooth operation. It took just a couple of seconds, and the book was on my Kindle.
Ray
It seems that the Kindle has some of the presentation problems with Adobe that the older Palm PDA software has had.
Plain and simple.... I gave up on it and went to a Netbook. Even the tiny EEEpc 7" screen had better full page presentation of graphic elements that electronic documents are so dependent upon.
What appears to have happened is that Adobe did indeed attempt to produce a 'fork' in there code specifically for small platforms, but development pretty much stalled as no one is really paying for the development. If Kindle does use that 'fork', you may never get the kind of clean PDF presentation that you expect from Adobe.
What apparently happens is the small screen software divides the data between 'text' and 'graphic elements'. And then, you have to click on and zoom in on graphic elements in order to see them. Normal Adobe just gives you everything as the document should be.
The results are very choppy as the original text has the reader able to glance at diagrams as they read, but on this form of software, that visual information is not immediately available AND the text is condensed into something that is less than appealing to read.
Still, there are some publisher (but not many) that are thoughtfully creating documents that do work in the 'small platform version'. The majority cannot afford to keep up with alternative.
In sum, 'thumbs down' to anything that doesn't provide a 'mainstream' version of Adobe reader on its platform. The alternative software is a deception and makes the hardware a complete waste of money for PDF documents.
It seems that the Kindle has some of the presentation problems with Adobe that the older Palm PDA software has had."
Loopy, what version of the Kindle do you have? I started my Kindle up this morning, thinking that I overlooked something, and to my amazement my Kindle does not have any "presentation problems". If your unit is still under warranty, maybe you should send it back.
To reiterate again, the PDF file(s) displays without any problems, on my unit. Maybe Loopy knows something about my Kindle, that I do not. Spill the beans Loopy.
Ray
Bill
On a side note, I do have Acrobat 9 Pro, so as long as PDFs are not locked for dis-assembly, I can tweak "ugly" PDFs so they view better on a kindle.
I don't own a Kindle, I have a Palm Zire 72. I was merely commenting that it might be that software similar to the Palm might be on it. The Palm would download PDF's, but it was never feasible to read them.
I doubt if I will ever own a Kindle as I live in Taiwan.
