Nec IR Transmitter
Hey,
Would it be possible to build a transmitter to send the hex value 43 for the data. I don't really seem to understand how to program the timing.
Nigel
Nigel
As to the receiving part, I've not worked on that, but I would expect someone will come along and discuss that. Also there is an IR Kit on the Propeller Object exchange and I think that has a receiving program?
http://obex.parallax.com/objects/category/9/?n=100
Here is my Sony volume down transmitting code as an example...
'SendSonyVolumeDown.spin Sends volume down IR signal to Sony receiver 'manufactured in 2007. Uses 38 kHz carrier. 'IR LED on pins 21(-) and 22(+). 'Red indicator LED on pin 0. CON _clkmode = xtal1 + pll16x 'System clock settings _xinfreq = 5_000_000 'External 5 MHz crystal VAR long StackSpaceSendBits[6] 'Stack space for SendBits cog byte Cog 'To store cog number of SonyBits cog PUB SonyReceiverVolumeDown 'Start new cog SonyBits - lower volume Cog := (cognew (@SonyBits, @StackSpaceSendBits)) dira[0] := 1 'Turn on red LED (Sending signal) outa[0] := 1 'Turn on red LED waitcnt(200_000_000 + cnt) 'Wait - Amount of time to send volume down cogstop(Cog) 'Turn off SonyBits (Stops sending volume down) dira[0] := 0 'Turn off red LED outa[0] := 0 'Turn off red LED repeat dira[1] := 1 'Flash green LED (No longer sending signal) outa[1] := 1 waitcnt(cnt + 10_000_000) dira[1] := 0 outa[1] := 0 waitcnt(cnt + 100_000_000) DAT ORG 0 'Begin at Cog RAM addr 0 SonyBits or dira, Pin 'Set IR LED - pin to output or outa, Pin 'Set IR LED - pin high to turn off 'Turn on 38 kHz carrier frequency or dira, PinFreq 'IR LED high pin set to output mov ctra, CtraNCOp22 'Set ctra for NCO single-ended output to Pin 22" mov frqa, CarrierFrequency 'Set frequency to 38 kHz 'Send start bit :loop1 mov Delay, Start_Bit_Mark_On 'Copy timing to Delay xor outa, Pin 'IR LED on :loop2 sub Delay, #1 'Subtract 1 from Delay djnz Delay,#:loop2 'When Delay = 0, goto next line xor outa, Pin 'IR LED off mov Delay, Space_Off 'Copy timing to Delay :loop3 sub Delay, #1 'Subtract 1 from Delay djnz Delay,#:loop3 'When Delay = 0, goto next line 'Send Volume Down 19 (1100100) LSB first call #OneBit call #OneBit call #ZeroBit call #ZeroBit call #OneBit call #ZeroBit call #ZeroBit 'Send audio device 16 (00001) LSB first call #ZeroBit call #ZeroBit call #ZeroBit call #ZeroBit call #OneBit 'Send two additional bits (10) unknown call #OneBit call #ZeroBit 'Send stop bit mov Delay, Zero_Bit_Mark_On xor outa, Pin 'IR LED on :loop4 sub Delay, #1 djnz Delay,#:loop4 xor outa, Pin 'IR LED off mov Delay, Stop_Bit_Space_Off :loop5 sub Delay, #1 djnz Delay,#:loop5 jmp #:loop1 'Send one bit subroutine OneBit mov Delay, One_Bit_Mark_On xor outa, Pin 'IR LED on :loop6 sub Delay, #1 djnz Delay,#:loop6 xor outa, Pin 'IR LED off mov Delay, Space_Off :loop7 sub Delay, #1 djnz Delay,#:loop7 OneBit_Ret ret 'Send zero bit subroutine ZeroBit mov Delay, Zero_Bit_Mark_On xor outa, Pin 'IR LED on :loop8 sub Delay, #1 djnz Delay,#:loop8 xor outa, Pin 'IR LED off mov Delay, Space_Off :loop9 sub Delay, #1 djnz Delay,#:loop9 ZeroBit_Ret ret PinFreq long |< 22 '+ Frequency Pin number Pin long |< 21 '- Pin number CtraNCOp22 long %00010000_00000000__00000000_00010110 '%00100 and pin 22 CarrierFrequency long 2039184 'A little under 38kHz Start_Bit_Mark_On long 24000*2 '2.4 ms milliseconds 2,400 µs microseconds One_Bit_Mark_On long 12000*2 '1.2 ms milliseconds 1,200 µs microseconds Zero_Bit_Mark_On long 6000*2 '0.6 ms milliseconds 600 µs microseconds Space_Off long 6000*2 '0.6 ms milliseconds 600 µs microseconds Stop_Bit_Space_Off long 213750*2 Delay res 1~Nigel~
Anyway 2 signals are shown. 38 kHz is RC2 and the bits are RC1. The same amount of time on/off (up/down) on RC1 is a zero bit. But a longer off period is a one bit. Sony is opposite and a longer on time is a one bit.
The second picture shows a closeup of a zero and one bit. With this you can see the 38 kHz below.
Anyway that is what the program above is doing. Sending 38 kHz out one pin and turning another pin on/off to send the bits.
As for a specific protocol, following is a LIRC database and there is an NEC folder there. These give the "specifications" of each IR signal for each manufacturer. Here is that link...
http://lirc.sourceforge.net/remotes/
Then here is all about LIRC...
http://www.lirc.org
Here it explains what the various settings in each LIRC specification are for...
http://winlirc.sourceforge.net/technicaldetails.html
As for sending Hex 43, the calculator in the programs/accessories which are on Microsoft OS computers has a View/Scientific mode. And this has binary, hex, decimal, etc.
So easy to convert that Hex 43!
That would be 1000011 in binary.
So that is what you would send. Some IR protocols send the least significant bit first. Others the most significant bit first.
So MSB would be sent as it is... 1000011
LSB would be sent backwards... 1100001
This is difficult stuff to work on! The problem is being able to "see" what is going on.
I use a Basic Stamp to measure the 38 kHz frequency. It helps to be sure you have that working OK.
Then I use IR capture on the Propeller to see the "bits". Following is the output of IR capture for the above pictures! Notice the larger numbers on some of the following? Those are 1 bits as shown in the pictures above for the Technics...
1,100
2,3455,1640
2,362,535
2,359,1356
2,362,513
2,352,540
2,362,513
2,352,540
2,362,513
2,352,540
2,362,513
2,352,540
2,362,513
2,434,458
2,362,513
2,416,1320
2,362,511
2,432,462
2,362,512
2,457,437
2,362,511
2,430,463
2,362,510
2,360,1379
2,361,510
2,362,1359
2,352,539
2,362,514
2,352,539
2,362,513
2,352,539
2,362,513
2,353,539
2,362,513
2,406,1331
2,362,512
2,460,433
2,362,512
2,459,434
2,362,1355
2,360,534
2,362,510
2,361,1359
2,377,514
2,362,514
2,352,538
2,362,514
2,352,539
2,362,514
2,352,1383
2,362,1093780
3
