Arrays in Assembler
                    Hi All;
I have wondered -and could not find an answer in the documentation- if one (or more) dimensional Hub Arrays defined at specific locations in a DAT section (prior to any Spin statements), as in the empty array:
Array byte 0[12]
could be referenced in PASM as in: mov Array[4],#17
If this is possible (fantastic!), then its not clear how to do it. The example method does not work.
Cheers,
Peter (pjv)
Array byte 0[12]
Cheers,
Peter (pjv)
Somewhere in your initialization code BEFORE the cog is started, you'd have something like:
address := @array + 4
If you don't know the array element address before the cog is started, you'd at least use this technique to get the address of the first element of the array, then add the index you want like:
Thanks for your quick response.
Oops, I picked a poor instruction to cite in my example.... I'm fully aware of the limitation of accessing HubRam from an assembler cog.
My question was really about syntax, hoping that a reference to an Array in Hub, already defined and loaded in a DAT section, could be effected with the array name and an index number.
A better example: rdbyte value,Array[7]
when the hub address and size (byte/word/long) of each array entry is already known by the assembler.
Cheers,
Peter (pjv)
Sorry to be difficult or persistent here, but .....
Well, all the variables in assembler are longs by definition, so containing the Hub Address in one should not be a problem.
And I don't understand what you mean with "the compiler doesn't know the address of the array when the code is assembled". I define and locate my arrays and variables ahead of any code, and I see no evidence that the assembler does not know the locations by name.... albeit there is a fixed offset that one must account for.
Now granted, I don't know any Spin (yet), so all my experience has been with assembler, but have never observed an address mismatch, and my code has been all over the map.
Is there some surprise lurking for me I don't know about? Perhaps with Spin??
Cheers,
Peter (pjv)
Some of this information, like the hub addresses of the various PRI / PUB sections and the starting addresses of the DAT and VAR sections, is stored in internal tables in the object code that are filled in late in the process of constructing the binary program file.
This is most interesting.
I have only CONs and DAT Hub Global Memory and DAT assembler sections, with the DAT globals defined first.
I have no VARs; only longs in Assembler.
I have is a Spin Cognew statement to launch everything, and it matters not where that is located.
The hundreds of (assembler) programs I have, and tens of thousands of compilations on those, there has never been an unexplained misalignment! So where does this "assembler not know" come from? My experience is totally to the contrary!
Something unexplained going on here..... for me at least.
Cheers,
Peter (pjv)
Once all the sections are processed, the fragments are assembled to form the binary file. The fragments for all of the VAR sections in the object are combined. In this process, the fragments are NOT changed. There are internal tables added, one for each compiled object containing the absolute hub address of the DAT sections of the object, the absolute hub address of the VAR information for the object, and the absolute hub address of each method in the object.
Because these are separate phases, the 2nd phase has no way to know where there might be references in the assembled code to the VAR area, so there's no way for the compile to "fix up" these addresses. This can be done at run-time using the @@ and @ operators in Spin, but not in assembler.
It's possible for the compiler to be redesigned and rewritten to be able to do these "fix up"s. It's not really a limitation of Spin, but it would be a lot of work. All of the existing Spin compilers work essentially the same way.
No, I have created the tables to reside in Hub Ram, and I was hoping to reference them by a somewhat more elegant method of their name together with an index such as Name[element], since one is able to allocate an array that way at compile time.
It seemed to me that the Hub address locations of the array elements were well behaved, and hence such a scheme should be able to work, but alas, I'm advised otherwise.
Then the whole issue of Hub based addresses not being defined at compile time just blows me away. Do realize I'm not running any spin codes, so perhaps that makes the difference, as strictly with assembler, I'm able to point at all the right spots in Hub to access data.
I need to better understand the proposition opposite to my observations, so I will have to do some experimenting. This could have a huge impact on the way I use the Prop.
Has anyone else experience similar to mine?
Cheers,
Peter (pjv)
If I recall correctly, BST has the @@@ operator, and I believe it provides the absolute Hub address at compile time. Will need to investigate.
Thanks again.
Peter (pjv)
You always need a small "stub" of Spin code to at least start up your assembly stuff in a cog with a COGNEW. I would simply allocate my hub variables in a DAT section (so the compiler doesn't rearrange the variables by size) and pass the address of the start of the DAT section as the 2nd parameter to COGNEW (the PAR register). All hub variable access then is relative to the value of PAR. You have to compute all hub addresses to the byte level anyway because of the way the RDxxxx and WRxxxx instructions work.
DAT base long ' other variables follow ' stuff array byte 0[12] PUB startItAll COGNEW(@assembly,@base) DAT ORG 0 assembly ' code starts here ' stuff mov temp2,par add temp2,#array-base ' must be < 512 add temp2,index rdbyte temp,temp2Thanks, and of course yes I have a starter stub to launch the assembler cog. I will do some experimenting with Spin code to attempt to determine the mechanism by which the addresses become no longer predictable.
Other than some experimenting many years ago when the Propeller was first introduced, I have been away from that silicon (focusing on SX projects) until this year, and that has been all assembler. Perhaps some day I will need to use Spin, but for now, assembler works great for me, and I'm able to squeeze a lot of performance out of a single cog.
Thanks for your insight and assistance.
Cheers,
Peter (pjv)
