Number of cogs remaining?
Hi,
Is there a way to know how many cogs are remaining?
I did that:
But maybe there is a better way?
I want to know that because I'm using many object from OBEX and I don't know why is using a COG, and which is not.
JM
I did that:
'' Wait 10 seconds to ensure everything is running and count the number of available cogs.
waitcnt(cnt + clkfreq * 10)
availableCogs := 0
repeat while (cognew(doNothing, @doNothingStack) <> -1)
availableCogs++
JM
I have a cog which manage the display. I will add that into it so I will always have an eye on the status.
Thanks for the suggestion.
JM
availableCogs := 0
availableCogs++
I tried the code several different ways, none of which worked.
1. Inserting the code as an object and I get the expected an expression term error.
2. By calling the DoNothing.spin code I receive Expected ".". error.
This I understand because the DoNothing.spin has nothing to return and no parameters.
I understand this may only be an "explanation code" but it sure would help if you would expain some of the hidden stuff.
I use the forum to learn doing things in new ways and it is very valuable to me.
But sometimes very frustrating.
Thank You
VAR long doNothingStack[10] long availableCogs PUB start '' Wait 10 seconds to ensure everything is running and count the number of available cogs. waitcnt(cnt + clkfreq * 10) availableCogs := 0 repeat while (cognew(doNothing, @doNothingStack) <> -1) availableCogs++ PUB doNothing 'Do nothing repeatedly repeatThen your cog counting loop should work.
I think you must have "repeat" in the doNothing otherwise it will finish execution, having done nothing, and the cog will be stopped. Then the same cog will be asked to do nothing again by your cog counting loop.
1) The above example only has one stack for starting all cogs. This is generally not a good idea but here it does not matter.
2) At the end of the cog counting loop all the cogs are used "doing nothing" therefore there are no free cogs and the result in availableCogs is wrong:)
Now, let's try to remove the issue #2 with PhiPi's suggestion:
VAR byte availableCogs long doNothingStack [10] byte availableCogsNumbers[8] byte cogNumber byte index PUB countCogs availableCogs := 0 repeat while ((cogNumber := cognew(doNothing, @doNothingStack)) <> -1) availableCogsNumbers[availableCogs++] := cogNumber if (availableCogs > 0) repeat index from 0 to availableCogs - 1 cogstop(availableCogsNumbers[index]) PUB doNothing 'Do nothing repeatedly repeat@Bluhair: doNothing is not a spin file, but a method into the current spin file. Also, on Heater's exemple, you need to indent "availableCogs++" to the right to have it on the loop. So you need to cut and past those 2 methods in your existing object to have them working. Same for the VAR section. Add them to your existing VAR section. Let us know if it's still not working for you.
JM
PUB doNothing repeatrequires 6 LONGS of stack.
How did you calculat that, and what is the stack for? I always give about 32 longs just to be safe. Is the stack used to store the cog code? Which mean is need to be as big as the Spin code translated in PASM will be?
JM
I did not calculate the stack size, I just kept reducing it until the program failed:)
The stack does not hold the cog code.
Consider, you can call the same method from many places in your code. Therefore it is necessary for the address at which to continue after the call has returned to be remembered somewhere. That somewhere is in the stack area.
Of course the called method can call other methods, again those return addresses are remembered on the stack. And so on.
Also if the called method has parameters they must be "passed" to the method some how. This is also done on the stack.
If the called method has local variables they will also live on the stack temporarily.
Finally the method it self may need some "scratchpad" working memory in which to evaluate complicated expressions. This scratchpad will also exist temporarily on the stack.
So as you see calculating the required stack size is in general rather complicated.
Normally you can make a guess and double it. Or keep reducing it until your program fails.
If you really want to know then define a large stack, run your method, when it is finished print out the contents of the stack array. There you will see where it has been writing or not.
P.S. Spin code is not translated to PASM. Rather it is translated to a sequence of byte code instructions which is then interpreted by a built-in PASM program running in the started COG.
A bit to much complicated for a beginner
Thanks!
JM
