LDR sensor code — Parallax Forums
LDR sensor code
wafa86wafa86 Posts: 44
edited 2010-10-05 10:08 in Accessories
hi every body
I wrote a code for LDR sesor for my circuit connect it to BS2PX module, the LDR is conncted to a LED with 2 resistor. The circuit should turn on the led when the LDR sense no light (dark) and turn off when LDR sense light. So I tried my code on my circuit, some times it works but some times it do the opposite function that the program does " turn on LED when light appears and turn off LED when dark" or it does not work at all. I think the problem is in the code because i tried to program the circuit using PIC18 with C language and it works perfectly. So I will paste the code here and I need help pleaze to fix the code
code:
' {$STAMP BS2px}
' {$PBASIC 2.5}
LdrValue VAR Byte
pin3 PIN 3 'ldrsensor
pin1 PIN 1 'leds
Baud CON 396 '9600 Baud
'RX PIN 2 'Receive Pin
TX PIN 0 'Transmit Pin
OUTPUT pin1
LOW pin1
'the lightness has levels from 0 to 255 and I choose 150 and beyond to turn LED on
LdrValue = 0
DO
here: SERIN pin3, Baud, [LdrValue]
DEBUG CLS, DEC LdrValue, CR
IF LdrValue < = 150 THEN
HIGH pin1
GOSUB here
ELSE
LOW pin1
GOSUB here
ENDIF
LOOP
thank u
    edited 2010-10-02 18:10
    First off you would not talk to a raw LDR with serial so you must have some form of module and in order to help you we need a link to that module.
    Second, if you have a gosub you need a return.
    Third, You should wrap your code with the code tags so the formatting stays in the code making it easier to read by others.
  • wafa86wafa86 Posts: 44
    edited 2010-10-03 10:44
    well, I do have a circuit "module" and I did not connect the LDR directly to BOE, this is the link to my circuit:
    http://img59.imageshack.us/f/ledldr.png/
    For the code I used before RETURN but it has the same result, the previos code as follows:
    ' {$STAMP BS2px}
    ' {$PBASIC 2.5}
    LdrValue VAR Byte
    pin1 PIN 1 'leds
    OUTPUT pin1
    LOW pin1
    LdrValue = 0
    DO DEBUG CLS, DEC LdrValue, CR
    Led_On:
    HIGH pin1
    GOSUB Led_off
    Led_off:
    ELSEIF LdrValue > 150 THEN
    LOW pin1
    RETURN
    GOSUB Led_On
    ENDIF
    LOOP
    do you have any other sugestion to fix the code???!!!!
    edited 2010-10-03 12:36
    edited 2010-10-03 13:09
    Download and read this. www.parallax.com/dl/docs/books/edu/wamv2_2.pdf
    Your code still is not even close to working, it's just wrong and you need to do some reading to figure out why.
    The input from the LDR is analog and you need to convert that to a digital representation. Try again after reading the pdf.
    edited 2010-10-03 13:39
    do u know any command that helps in converting from analog to digital representation? or it needs a kind of equation????
    edited 2010-10-03 15:23
    RCTIME but read the book.
    edited 2010-10-04 17:32
    I agree with Franklin. Old-school photocells or photoresistors (pedantics call 'em LDRs) are not precision devices, not sure why your module uses a serial connection. Silk purse/sow's ear syndrome. Just RCtime a direct connection to a photocell and call it a day. They're cheap, even Radio Shack has a 5 pack for 3 bucks.
    http://www.hosfelt.com/contents/en-us/d583.html 25 cents
    http://www.radioshack.com/product/index.jsp?productId=2062590
    thanks alot I ll try your advices and use RCTIME maybe it will works.
