Delay audio/data between 24bit ADC and DAC
Hi there, for a project i would like to delay audio in between 24bit 96khz ADC and DAC's. The goal is to control the delay in a precise manner, between 5-50ms. Although i've read a lot about the propeller, im not sure if its capable of doing this (big stream of data). Could anyone explain to me if this would be possible?
(stereo would be even better, but mono - so single audio stream - would be fine for now)
1sec = 1000ms
50ms = 1/20th of a sec
24 bits @ 96Ksps = 288,000 bytes per sec
So if we used a circular buffer, with three bytes per sample, for the maximum specified 50ms delay we would need the buffer to be 288,000/20 = 14,400 bytes
Therefore, the answer is yes - it is possible.
Note that the buffer manipulation would be simpler and faster if you used a long for each sample, in which case the buffer would have to be 19,200 bytes. This precludes doing stereo.
If you could live with preserving only sixteen bits, you could use a 9,600 byte buffer, which would allow for two circular buffers for stereo sound.
-- http://www.openstomp.com/wiki/index.php?title=Main_Page
If i understand correctly, i can use SPI RAM like localroger suggests, to get the performance i need for a stereo delay at 24bit?
Either way, im impressed with the numbers and will have a go at it as soon as possible
