servo programming — Parallax Forums
servo programming
jdnphotojdnphoto Posts: 5
edited 2010-09-29 13:05 in BASIC Stamp
Can anyone tell me if there is a way of programming a servo to change position by one increment each time through a loop. Example first time through loop pulsout 14, 750 next time through loop pulsout 14, 800 and so on until loop is completed by counting. Thanks for you help.
    edited 2010-09-29 06:59
    Sure, use a FOR loop like this:
    FOR i = 750 TO 2000 STEP 50
    PULSOUT 14,i
    PAUSE 20
    NEXT i
  • jdnphotojdnphoto Posts: 5
    edited 2010-09-29 07:10
    I tried something similar and all it did was rotate the servo from 750 to 1000.
    Here is part of my program so you can see the total picture. Please look at the "'TILT"
    PULSOUT HB25D, 500 + 129 ' FORWARD MOTION
    PAUSE 20
    PULSOUT HB25H, 500 + 50 ' UP MOTION
    PAUSE 20
    SEROUT 10, BAUD, ["[E159}"] ' ROTATE
    GOSUB CHECKBUSY2
    PAUSE 10
    CHECKBUSY2:
    PAUSE 10
    CB_LOOP2:
    IF IN8 = 1 THEN CB_LOOP2
    PAUSE 100
    FOR TiltPrevPosition = 750 TO 1000 STEP 4 'TILT
    PULSOUT 15, TiltPrevPosition
    NEXT
    PAUSE 3000
    LOOP UNTIL (COUNTER = 62)
    edited 2010-09-29 07:21
    You have to have the PAUSE statement in the loop. A servo expects a control pulse about 50 times a second and cannot respond to pulses more frequent than that. Make the STEP size large enough so the servo moves through its range as quickly as you want even through the pulses (and loop steps) are only occurring 50 times a second.
    edited 2010-09-29 07:24
    Thank you so much I will try that.
    edited 2010-09-29 09:43
    Also make sure you have a RETURN at the end of your Checkbusy2 routine. Can't tell from your edited program listing.
    edited 2010-09-29 12:29
    I tried the following code. The servo "tilt" goes through all steps before advancing the main loop. I need it to move (step) 4 then hold this position until the main loop returns to it the next time. Then move (step) 4 hold again and so on.
    Routine2:
    DEBUG "Routine 2 is running", CR
    Initialization
    DO: LOOP UNTIL HB25D = 1 'Wait for HB25 Power up
    LOW HB25D 'Make I/Opin Output/Low
    PAUSE 5 'Wait for HB25 to Initialize
    PULSOUT HB25D, 750 'Stop Motor 1
    Initialization HB25H
    DO: LOOP UNTIL HB25H = 1 'Wait for HB25 Power up
    LOW HB25H 'Make I/Opin Output/Low
    PULSOUT HB25H, 750 'Stop Motor 2
    PAUSE 1000
    Program Code
    UpCounter = 0
    DO
    UpCounter = UpCounter + 1
    PULSOUT HB25D, 500 + 129 'Forward 1/4"
    PAUSE 5000
    PULSOUT HB25H, 500 + 50 'Up 1/2"
    PAUSE 5000
    SEROUT 10, baud, ["{E-150}"] 'Rotate
    GOSUB checkbusy2
    PAUSE 5000
    checkbusy2:
    PAUSE 10
    CB_loop2:
    IF IN8 = 1 THEN CB_loop2
    PAUSE 100
    PULSOUT Tilt, TiltPrevPosition 'Tilt
    PAUSE 5000
    NEXT
    DEBUG BELL
    PAUSE 3000 'Hold for 3 seconds
    LOOP UNTIL (UpCounter = 62)
    GOSUB Routine3:
    edited 2010-09-29 12:51
    Please re-read erco's reply. Your program logic is in trouble and the program will eventually stop working since you have GOSUBs without RETURNs.
    Your existing FOR loop won't work particularly well. You have a PAUSE 5000 in the loop which means that the servo will get one control pulse every 5 seconds. That won't work. Servos need control pulses every 20ms or they'll shut themselves off. That causes mechanical jitter and slippage.
    I think you need to back up and talk about what your program is supposed to do. Go back to a flowchart or some similar sort of diagram, even a written list of actions and when they occur.
  • Daniel HarrisDaniel Harris Posts: 207
    Try this:
    Routine2:
    '------------Initialization----------------------------
    '------------Initialization HB25H----------------------------
    PAUSE 1000
    '------------Program Code-----------------------------
    UpCounter = 0
    '----------change here --------------
    DO
    PAUSE 5000
    PAUSE 5000
    GOSUB checkbusy2
    PAUSE 5000
    checkbusy2:
    PAUSE 10
    CB_loop2:
    PAUSE 100
    TiltPrevPosition = TiltPrevPosition + 4
    DEBUG BELL
    GOSUB Routine3:
