Need a new Laptop - any suggestions? — Parallax Forums
MicrocontrolledMicrocontrolled Posts: 2,461
edited 2010-09-28 23:59 in General Discussion
''////////SKIP THIS PART IF YOU WANT////////////////////////////////////////////////////////////////////////////////////////////
As some of you know, for the past 5 years I have used a mash-up computer for programming. It started out as a Windows 98 HP compact, but then i put the HD in a newer Gateway running Windows ME. Later I upgraded to XP with a recovery disk from another computer, and about the same time I raided 2 HPs for RAM and put them in the Gateway. Over the course of 2/1.5 years, it crashed twice. Eventually I got a Dell Inspiron desktop which I moved all the parts except the motherboard into.
Yesterday it crashed (it had before on the Dell) again and the bootloader was throwing an error. I finally after messing with it got it to boot, which I backed up ALL my data. After shutting it down again and starting it back up, I got multiple errors, including keyboard and mouse errors.
ANYWAY, I finally decided that I need a new computer. And preferably a laptop. Right now I'm using a borrowed computer (Gateway Laptop) running Ubuntu (my doing :-)). I looked at WalMart today at the laptops (hold your tongue here...) and found one I liked well, an Acer Aspire with 3GB RAM 250GB HD 1.89GHz processor. It has a built in webcam, speakers, HDMI out, number pad, gesture control, and 17.3" LED screen for $500. I liked this one the best, even though there where more capable computers there. However, Acer isn't a top computer brand, and I wanted your opinion on it.
So there's my option, but I want your opinion: what is your laptop of choice? I'm comfortable with spending $500, and might be able to stretch to $600. I prefer an Intel processor, although I could live with an AMD Vision if it outweighs heavy enough. Disk drive is a must. In addition to programming I will also be working with animation rendering in Blender 3D which really takes a toll on your computer.
Your opinion is valuable to me.
Micro
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2010-09-28 14:23
    If you go up a bit to the starter business line, I think in the long run it would make you happier. Here is a vostro, smaller screen though. http://configure.us.dell.com/dellstore/config.aspx?oc=bvcs5f1&c=us&l=en&s=bsd&cs=04
    If you are like me, You'll want a real serial port. You can still get one if you want, but not at wal-mart.
  • zappmanzappman Posts: 418
    edited 2010-09-28 14:48
    Hi Microcontrolled,
    At home I almost always use my self built desktop.
    But in November 2007, I bought an ACER Aspire Laptop to use for travel, during Walmart's Black Friday sale. It was only $299. No problems to date. I have upgraded it 3 times, more memory, larger hard drive and a DVD Burner.
    Bought my younger son (he is in college) a Gateway FX Laptop in June 2008, he has had no problems.
    My older son used to have a HP Laptop (Compact Computers are also HP), it was a piece of junk, died twice under warranty. Died a 3rd time right after the warranty expired, so he bought a new one, he didn't by an HP for the replacement.
    At work we use Dell Laptops, they hold up very well.
    zappman
    edited 2010-09-28 14:56
    I know laptops are all the rage, but they are only one good drop away from being doorstops. I bought a little Acer Aspire 1 netbook for $200 that is good for traveling and light duty portable work. Works great, as long as you don't expect too much. Perfect for some videos, web surfing and programming Stamps down on the floor with the robots & babies. My main computer is an HP desktop. Cheap, plenty of power and lots of room for upgrades. Easy to share files & apps between computers. Best of all, if & when the Acer gets dropped, all my files are still safe at home in the HP.
  • schillschill Posts: 741
    edited 2010-09-28 15:14
    17" laptops are pretty big if you actually want to move it around. I'd consider a smaller size - especially since the resolution is usually the same.
    Looking only at resolution, I have three laptops/netbooks that I switch between depending on what I'm doing or where I'm taking it:
    1) Dell Studio 15 (15" 1920x1200 <- I like high resolutions)
    2) Asus UL30VT (13" 1360x768 <- I consider this fairly low resolution for my day-to-day work/play)
    3) Asus EEE 1005? (10" 1024x600 <- Usuable primarily because of the convenience of the small overall machine size)
    For most of my day-to-day use when I'm sitting at my desk (at home), I'm using a desktop with dual 1600x1200 21" monitors.
    I like a lot of screen real estate if I can get it.
    If the 17" display is only 1360x768 (or so) which some are, then I would avoid it. If it's 1920x1080 that's good, but it's still a big machine and not very portable. If you don't need the portability, a faster desktop should be cheaper.
    I've given up on serial ports on laptops. But I'm pretty happy with FTDI-based USB-serial adapters and I haven't had any issues.
    By the way, I really like the UL30VT. It's not the fastest machine out there, but it's small, light, and I can get over 10 hours of light usage out of one battery charge.
    edited 2010-09-28 16:34
    You can easily get positive and negative replies on just about every laptop made. I only bought Dell up until about 7 years ago and since then my laptop purchases have been HP. I bought an HP media laptop with XP-MCE and have been very happy with it. My last laptop purchase was for my wife and was another HP Media Laptop with Win7. It's working out very well. At work, I have an HP Compaq 6715b with a handful of upgrades and now matter how hard I beat on it, it keeps working great.
    In regards to the animation software, look for a laptop that has dedicated video RAM (as opposed to sharing main RAM). I wanted that for my wife's and that is one reason why I settled on the HP media laptop.
    Depending on specs needed, there's probably a handful of us on the forums that could send you various parts to piece together a decent machine......
    edited 2010-09-28 17:31
    I've gotten a PM and a message in favor of the Acer, so I'm highly considering it since I liked it so much already. I can upgrade the computer with ease (I love taking apart computers!) so when funds have amassed I can upgrade RAM, HD, etc. As for size that is not a consideration. The thing is when I set down at my electronics desk I will stay there for several hours, and sometimes I would like to go and do my programming elseware, since I already have my Propeller development mobilized. I can't do this with a desktop, obviously. This could be just a room over, or just downstairs, so portablity isn't a big issue.
    Thanks for the great response!
    Micro
  • WhitWhit Posts: 4,191
    edited 2010-09-28 17:34
    I love laptops. I do travel a good bit with mine. I is so handy. My current laptop is an HP. I have had it for 4 years without any problem. I am about to get another and make this my robot hobby laptop.
    Have fun!
    edited 2010-09-28 17:44
    I'm really trying to aviod the HP, as the only HP we have ever owned isn't exacty the "speed demon". It takes 10+ minutes to boot and another 5 before it runs smoothly. When we ask someone to get it turned on for us, we usually say "Can you get the slow one turned on?"
    The motherboard also exploded once. Yes. Exploded. Lucky for us, they had just issued a recall even though the computer was 2 years old.
    The only other HP I've worked with is one for my grandparents and it is a piece of junk. It is allways having network problems and always gettin disconnected (we have to reenter the net key) that are not evident with the Gateway computer we brought over to test it.
    So anyway, HPs are not something that I favor. I have had some good experience with Dells, though.
    edited 2010-09-28 17:51
    Personally I love my little Netbook. Granted I would have purchased an ASUS instead of the MSI, but only because of the better battery life.
    Dual core, easy to slep around and prices are around $300. range.
    OBC
  • icepuckicepuck Posts: 466
    edited 2010-09-28 17:55
    If you need to run windows for anything pick win7 pro or XP pro. Don't waste your time with anything less. who ever the idiot was that thought win7 starter would be good for my HP mini with 1gb of memory should loose his job. I also have a Dell mini (XP home=evil) now running ubuntu.(linux=peace)
    -dan
    edited 2010-09-28 18:04
    I think I'll duel boot with Linux (Ubuntu) on my laptop since I've recently found a liking for it. Netbooks are out. I like big keyboards, big screens. The kind of laptops I'm looking for is more of a "portable desktop" because I like to be able to move my computer if I want, but nowhere that would require small size. Besides I'd catch my netbook on fire rendering an animation with full raytracing and compositing, which most of mine do.
    edited 2010-09-28 18:29
    I have an MSI Wind u100 which is dual boot Windows XP Home and Ubuntu Netbook edition. I have had it for two years and it was almost $400 when I bought it, but they are $200 now. I like it and Ubuntu with the Chromium browser runs well on this machine.
    edited 2010-09-28 20:07
    My current laptop is an IBM ThinkPad T23 (Pentium III, WinXP Pro) that I bought refurbished from www.thinkpaddepot.com in 2006. I chose it above more recent models because it doesn't have one of those stupid trackpads. It's no racer, but it is solid, as one would expect from an IBM product. It does everything I need it to do; but, then, I don't try to run Blender on it.
    edited 2010-09-28 20:36
    Acer has the highest failure rate over 3 years its 24.6 % (Yahoo poll last year) ...
    I had a one book . Junk ! the bezel cracked the screen in less then a day .
    Me its a toughbook or a Mac with 3 way boot .
  • RavenkallenRavenkallen Posts: 1,057
    edited 2010-09-28 22:23
    i have had good luck with the toshiba satellite laptops. i had one that lasted like 5 years.. they seem to be built pretty well and they are cheap..
    edited 2010-09-28 23:49
    I guess since my post may have been a bit "pro HP", I figured I should mention that my daily use laptop at home is an 8 year old Dell Inspiron 1100 (P4 single core 2.4GHZ with 640MB RAM). With a clean load from the restore CD earlier this year, it still boots XP in less than a minute. I found a fan utility from a Russian site that allows me to tweak the fan operation, so I don't have the typical overheating issues with Inspiron laptops. I use this laptop currently for propeller programming, web development with Dreamweaver/Fireworks/Flash, email, and all my other day to day stuff. It does well with the power hungry programs; I just force the fan to max speed and give a bit more time to do things.
    It would be nice to have a desktop stationed on my workbench for the bulk of my programming, but since my workbench is not a permanent setup in it's current configuration, I have to have a laptop. (the den is also our portrait studio so I am limited on furniture placement) A netbook would be nice for checking email, basic surfing, and propeller programming, but not as the sole laptop I use since I have a few power hungry apps.
    Acers seem good. The brand has always had trouble getting recognized in the USA, but Acer has its roots as the OEM Taiwan provider for many other brands.
    But I tend to lean toward Asus for Taiwanese manufacture as they are a major motherboard supplier for others. Again, this is the branded side of their rather vast OEM business. They managed to develop very good relations with Intel by providing motherboard for Intel when Intel's in-house motherboard were not working well.
    Recently, my Asus EEEpc died and I purchased a Toshiba NB250 for $300USD with Windows 7 Starter included. There is plenty of room for a dual boot with Ubuntu Netbook as the hard disk is well over 200Gbyte, though they claim it is 200Gbytes (hidden Windows 7 backup glut).
    I've always like Toshiba as the tend to build a bit rugged. Their little netbook is quite fine, but only has one mono speaker. I suspect the Koreans are being more aggressive and trying to take business away from Taiwan, so Toshiba might currently offer more value.
    The Taiwanese are making the majority of laptops sold globally under various brands. So why not go with the OEM through their in-house brand and save a bit. Gateway doesn't existing in Taiwan, Dell is barely here. Everyone here is happy with Acer and Asus, and I even have a Lemel Core 2 Quad. But I would say that Lemel can be a bit too generic and funky.
    HP, Apple, Dell, and IBM - all are generally Taiwanese under the hood.
