100% SPIN NTSC video driver — Parallax Forums
ericballericball Posts: 774
edited 2010-09-25 09:47 in Propeller 1
Including the WAITVID instruction in SPIN has always seemed a little pointless to me. Although the video generator can be used to for other reasons, SPIN is too slow to generate video. Or is it?
Attached is a a demonstration of generating NTSC video with just SPIN code. It's admittedly low resolution (32 pixels across and only 4 colors for the whole screen), but it does prove it's possible. (It's also a testament to how tolerant TVs are to out-of-spec signals.)
Useless - yep. Well, unless you want a giant 2 character display. The problem is the cog is fully utilized, so there's no advantage to using the SPIN routine instead of a PASM driver.
There's also a quirk I haven't figured out. In theory it should be possible to change "colors" in NTSC_demo.spin after COGNEW and have it change onscreen, but it doesn't work.
Timing notes:
1. Constant 0 is fastest, followed by global and local VARs (at least the first 8), small constants, 32bit constants, and DAT being the slowest.
2. The reason I had to create the p+=8 section was it would lose sync if put in the normal spot after the inner REPEAT.
3. WAITVID( lvar, LONG[lvar][2] ) takes 1232 cycles, which means there's only time for 3 WAITVIDs per line at 80MHz.
4. Trying to handle PAL colors would take additional cycles, making it basically impossible in SPIN.
    edited 2010-09-24 19:29
    Excellent!!
    edited 2010-09-24 19:39
    ericball: Excellent - just shows how versatile the prop is :smilewinkgrin:
  • BaggersBaggers Posts: 3,019
    edited 2010-09-25 09:35
    excellent ericball :)
    edited 2010-09-25 09:37
    Very cool...
    Since Prop2 will be 8x faster, 256 pixels should be possible horizontally on it - in spin!
    ericball wrote: »
    Timing notes:
    Yeah, and high colour :D, how strange will that be for spin!!
