OBEX Search problem — Parallax Forums
OBEX Search problem
edited 2010-09-27 22:17 in Propeller 1
I was trying to search the Object Exchange for "SerialMirror" but the search result only showed "MultiCogSerialDebug" an object based on SerialMirror.
I managed to find it by searching for just "Serial" and scrolling thru the results.
Curious...
  • Bobb FwedBobb Fwed Posts: 1,119
    edited 2010-09-24 09:42
    The problem is, and Parallax really needs to fix this, the search only searches the description. It does not search the title. This is a big problem. I have been adding the name of my object as the first line of the description, and that fixes it.
    The best method to search the OBEX is to use a site restricted Google search. So, to search for "SerialMirror" as you stated, put this into a Google Search box:
    SerialMirror site:obex.parallax.com
    first hit.........
    SerialMirror - Propeller Object Exchange
    Jul 9, 2008 ... SerialMirror. A FullDuplexSerial enhancement that allows a single serial connection to be used from within multiple spin files. ...
