X-band radar sensor
Has anyone used the x-band radar sensor, Parallax item # 32213? That is other then doing the sample demos. It appears to be a very interesting sensor, but I have seen only a very few past threads about it in the forum and not much activity. Would appreciate suggestions or where to go for discussion on it's application and more advance programming on item#32213.
Thanks much.
Thanks much.
I was surprised when it detected movement thru the brick walls of my house.
I set up two basic stamps - one with the X-band sensor and an XBEE transceiver, the other with an XBEE and an LCD display.
I pointed the X-band sensor toward an outside wall and went outside with the other unit. As I walked within a couple of feet of the brick wall, it detected the movement.
I've found specific devices that match my requirements (e.g. Houston Radar products, etc) but they're quite expensive (around $500) for a hobby project !
So I was thinking of using the much cheaper X-Band radar sensor instead. However, the documentation states that:
Motion Detectors antenna has a wide radiation pattern to convert velocities from multiple points to
oscillations that notify the microcontroller that movement was detected. This device is designed to detect
motion, not to determine speed of a moving object. However, an application may still use a rearranged
version of the Fd equation to determine speed provided everything else in the detection area stays still.
The "wide radiation pattern" might be problematic in my case. Is there a way I could make it "narrower"?
As for the equation, what kind of "rearrangement" would it require to accurately calculate the speed of a moving object?
Thanks for your help!
V = cyclespersec*30000/2105 gives you mm/sec
V = cyclespersec*30000/53467 gives you in/sec
but what is the accuracy and under what conditions I dont know and I haven't tested the accuracy against a known source.
Also note the supplied driver gives you cycles in the measurement time not cycles/sec
I've finally managed to get my hands on a X-Band.
My initial quick tests showed quite "erratic" readings...
So now the question is indeed how to get an accurate speed measurement out of the sensor.
First, I think I need to narrow the RF beam, following the advice in this thread.
-g
