Frequency response of a piezo speaker?
Hi all, im working on a project to generate a swept audio frequency from 30khz to 60khz through a piezo speaker, like the BarkOff contraptions for sale. basically, it produces a frequency between 30khz to 60khz that dogs can hear, whenever a loud sound is detected with a microphone, (like a dog's bark) that is supposed to irritate dogs to make them stop barking (supposedly). I've got the circuit and programming made in .spin, using the PropLab design platform, and verified the frequency is being generated as desired with a o'scope. the thing im not sure of it that the piezo speaker is capable of producing frequencies in that range. i've tried the circuit, using my mother's lil 'ankle-biter', missy, as my 'lab rat', but she just lay's there and looks at me, then goes back to sleep, so im not sure that the piezo speaker is actually producing the sound. i've google'd for the answer but haven't came up with any useful info. im thinking that the frequency response of any given piezo speaker will be dependent on the size of the element itself. can anyone verify this? anyone have any ideas?
Thank you for any input and/or suggestions!
I really doubt you're going to get 30kHz out of a piezospeaker from the lab kit. You'll probably have to find a transducer with a center frequency in the 40kHz range.
I also thought about that too, i have another piezo speaker in my stash o' parts that is around 1 3/4" to 2" in diameter. i'm going to try it and see if i have any better results. i was just wanting to verify what the actual freq. resp. is for these before i started digging.
I didn't want to start 'barking up the wrong tree'!
:smilewinkgrin:
:rolleyes:
Thanks for all the feedback guys, i really appreciate it!
http://williamson-labs.com/sdi.htm
Ultrasonic piezo transducers are narrowband (like the one on the PING))) have a relatively sharp resonance and must be driven near their design frequency. Readily available frequencies are 25, 34 and 40 kHz. You could probably obtain good results with a mix of those frequencies or by driving ensembles of them at nearby frequencies to create beats.
The problem is this: piezo elements usually have strong resonances, which means they provide the largest amplitude (loudest sound) when driven at a very narrow band of frequencies. If you try to drive them at a frequency far away from their resonance frequency, their sonic output might drop to nearly zero, so it probably won't matter if you amplify the driving signal or not. Most piezo speakers you get at Radio Shack, etc. are designed to be used in the audible range, so they might have resonances around 3kHz or 5kHz, etc. To get up to 40kHz, you need something with its resonance in that region.
Edit: A friend of mine warns that even though we can't hear these high frequencies, we can still get hearing damage from them. So don't shove your ear against an apparently silent transducer.
I once had a remote control car that used ultrasonics for the control scheme. The lower harmonic was right at the edge of human hearing.
As a little kid, I could hear 22Khz. Verified it later in life, when I knew how, based on sources I heard earlier. Now it's sort of 18Khz, maybe 19 in the better ear, when it's clean, and it's really loud! (like that actually, because the little bit of roll off eliminates a lot of messy bits found in a lot of gear today) I'll bet it starts to roll off from the response it used to be, starting at 14 to 16Khz.
Anyhow, the toy used a mechanical means to generate the signal, and it was actually LOUD, but just high in frequency. After listening to it up close a few times, my right ear rolled off it's high frequency response for DAYS. Came back, with a little tiny ring that faded after a considerable length of time.
I never did it again, despite it being a very compelling sound! Almost nothing in life resonated at that range, and it was this nice, pure, really high tone
Now, being older, I've a few ringers below 20db or so. Almost never hear them in ordinary life because the noise floor is often above that. When it's really, really quiet, there they are! --and slowly worsening, which is why I use protection religiously now --might just be an artifact of age. I suspect that, but am taking no chances at all.
Thanks again for everyone's time and effort in helping me silence the dog!:smilewinkgrin:
My wife's dog either doesn't care, or can't hear these frequencies.... Too bad too, cause I was going to have some fun
http://www.steminc.com/piezo/SMATR15F45H5.asp
Are you going to need some sort of transformer to use them?
Let us know how it they work out.
Duane
I clicked on the link above, on the steminc site, and that is not a piezo speaker.
The part number SMATR15F45H5 is an Air Transducer and not a piezo speaker. You can use it to send and receive signals at a range of 2 meters. It works on the same principle of the sensors on the back bumper of cars. You can use them on robots as a directional device, distance sensors and frequency listening device.
On the same web site I found the multi layer piezo speaker part number SMSPK2724300.
This is a small size loudspeaker multilayer piezoelectric ceramic. This multilayer ceramic wafer is characterized by low operation voltage which makes it suitable for mobile applications such as cellular phones, gaming devices and others.
I hope that helps.
Regards
Grenoble
In ultrasonics you get transducers for solids/liquids and transducers for use in air (the extreme difference in acoustic impedance between air and solid/liquid means the same design of transducer cannot perform well in both situations).
Air transducer is the scientific way of saying speaker (or microphone or both).
