Temperature graph — Parallax Forums
Temperature graph
KARIM102KARIM102 Posts: 75
edited 2010-09-17 17:04 in Learn with BlocklyProp
Hi everyone, i would like to know which software is the best for Tmp graph... i wanna use the prob temperature to montor the temp with time .... i will use basic stamp and prob temp.... what's the software i need to draw the graph bettween temp and time ....
    edited 2010-09-17 15:23
    If you want to make plots on an attached PC, look at StampPlot Pro which is downloadable from Parallax's Stamp Downloads page. If you want to make plots using the Stamp itself, that depends on the type of display you're using.
    I will second what Mike said, I used stampplot when I was testing my SHT11 modules a couple years ago and was really happy with how well it worked.
    If you are looking at using a composite video monitor for a display, you can look at the Propeller Backpack to partner with the stamp.
