BS2 - Fixed!
I fragged one of my Stamps, I stuffed an output (ouch) while doing some "mythbusting."
I ordered a replacement interpreter/PIC.
SSOP ain't too bad.
Here's how I did it:
1) I gooped up the IC pins with paste flux (which looks a lot like axle grease)
2) I went back & forth along one row with the soldering iron's generously tinned tip while gently cranking with a pen knife till that side popped away from the board
3) Holding the IC with a needle-nosed (noodle-knees) pliers, I did the back & forth on the remaining row and pulled it gently away
4) I cleaned the pads with solder wick
5) I tinned a corner pin's pad and then situated the IC atop it and touched it again with the tip (verify proper alignment)
6) With a bit more flux and my generously tinned tip, and some extra solder at the ready, I did a drag-solder along the pins opposite the tack-soldered pin's side
7) I drag-soldered the remaining side
8) Finally, I wicked the bridges and did a close visual inspection
Next thing I know, I'm back on the air.
My tip is a pointed one (a Weller ST-7), but it's not of the fine tip or bent sort, no big deal.
SSOP ain't too bad.
Congratulations! It is nice to try something like this and it works! Kinda makes you feel like a wizard.
Humanoido
Humanoido
http://www.chipquikinc.com/
Chipquick is a package of stuff all of which some blokes may not have sitting around, but it looks the same as my procedure, for all intents and purposes, and I have all of the supplies on hand. If you have the soldering skills, but not the supplies, then Chipquick looks like a sound option.
Since I didn't want to grip the BS2 pins, I placed the Stamp itself in a 24-pin socket which I then held in my Pana-Vise (Pana-Vise Jr., actually.)
[Thanks everyone for your kind notice. ]
All the steps are the same except for 1 and 2. Since the leads on the chip are tiny I've found that you can cut them on one side. You need to be careful not to nick the board however! With a steady hand I've used a new utility knife to sever the leads right at the package. From there just bend the chip back and the other side will break off. You can also use an exacto or a dremel to cut the leads.
From there just use some fresh solder and the iron will pickup all the leftover lead parts and wipe them away on the sponge. A bit of solder wick makes the pads ready for the new part.
Robert
