Pepper SPIN with Assembly?
I'm writing some arbitrary SPIN code and I see lots of small
snippets of assembly code that I would like to use, like this.
To what degree can these small snippets of assembly
code, without any other support, be mixed with SPIN?
Thank you in advance.
Humanoido
MOV $1F4, #$FF 'Set OUTA 7:0 high
Humanoido
Problem is that to run any PASM instructions you have to get them loaded into a COGs memory space first.
The Cog that is executing your Spin code is already full, with the Spin byte code interpreter. Even if it were not full it's unlikely any one would design the interpreter to suck in any old instructions and run them [See note 1].
So you would have to load that PASM into a different COG. But you can only load a whole COG (496) LONGs so it would be a slow process just for a couple of instructions.
Even if you do that you are then left with the problem of communicating with that PASM snippet through HUB memory. It's just not worth it.
So result is "Not at all."
Note 1: I'm considering allowing the Zog byte code interpreter for C to allow loading and executing of any PASM instruction as it runs. Not intended for use by application programs but as a way for C code to be able to do waitxxx and hubops like COGINIT etc.
version of the spin interpreter that allows this?
Store this version on the upper half of a 64kb eeprom, and load a cog with it
and end the current rom based interprete cog.
I'd find this sort of thing useful, for both writing programs, and also for learning pasm, as you could take a single pasm instruction and put it in amongst some high level code that might read a keyboard, or print something to a screen, and then you can experiment with pasm and debug code fragments more easily.
... but for small code snippets, this has been working really nice for me. It might help others as well.
http://obex.parallax.com/objects/665/
or in the code below...
{{ ************************************************ * InLine PAsm in Spin Demo v1.0 * * Author: Beau Schwabe * * Copyright (c) 2010 Parallax * * See end of file for terms of use. * ************************************************ InLine Assembly? - debatable perhaps, however this allows you to call snippets of PAsm and run them as if they are a defined PUB or PRI subroutine without having to reload a new COG every time. This program starts a single COG engine which is similar to 'other' dispatch type of PAsm programs such as 'graphics.spin'. What makes this different is that the PAsm that would normally be dispatched within the PAsm dispatcher program now resides in Spin and because of that can be more dynamic (customized) from within the Spin environment even making some LMM programming possible. Revision History: (sometime before) - I have been using a form very similar to this for testing small bits of code for awhile. There has been some recent talk in the forums so I decided to clean up what I hav and sumbit it. 09-13-2010 - initial release }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long InlinePAsm,ARG0{...,ARG1,ARG2,ARG3, etc.} PUB SpinCode cognew(@PAsmEntry,@InlinePAsm) 'Start Inline PAsm engine - You only need to launch this once ''Example 1 Inline(@PAsm1) 'Call Inline PAsm: ' - set all LED's on Propeller Demo Board HIGH ' - program returns to Spin after LEDs have been set in PAsm ''Example 2 ' Inline(@PAsm2) 'Call Inline PAsm ; ' - how to make jumps .. wiggles P0 at 5MHz ' - program remains in PAsm loop does not return back to Spin ''Example 3 ' ARG0 := %11001010 ' Inline(@PAsm3) 'Call Inline PAsm ; ' - how to pass an argument from Spin to PAsm ' - program returns to Spin after LEDs have been set in PAsm ''Example 4 ' Inline(@PAsm4) 'Call Inline PAsm ; ' - how to pass an argument from PAsm to Spin ' - program returns to Spin after PAsm changes ARG0 ' dira[23..16]~~ ' outa[23..16]:=ARG0 repeat DAT {{ Enter valid Assembly code here in this section, there are just a few stipulations/requirements you need to consider about how variables are used, and how jumping is achieved. Because addresses and variables are local to each COG and how the IDE computes adresses it is necessary, when running 'PAsm code snips' to make relative jumps from a known position. }} ''################################################################################################ ''################################################################################################ ''################################################################################################ ''################################################################################################ '' InLine PAssembly code example 1 ''################################################################################################ PAsm1 long PAsm1_End-PAsm1 '<-first value must contain InLine PAsm program ' length in longs mov temp0, #%11111111 shl temp0, #16 mov dira, temp0 mov outa, temp0 PAsm1_End '<- place this at the end of each InLine PAsm ' for a convenient way to calculate program ' length '' InLine PAssembly code example 2 ''################################################################################################ PAsm2 long PAsm2_End-PAsm2 '<-first value must contain InLine PAsm program ' length in longs {0} mov temp0, #1 {1} mov dira, temp0 {2} xor outa, temp0 {3} jmp #InlineProg+2 ''   Note: In order to jmp to any location within the InLine '' │ │ PAsm code, you must do it with reference to where '' │ │ your Inline code starts. This means that YOU must '' └───────────────────────────────────────── keep track of the PC location and add it to '' └─────────── 'InlineProg' to get an effective jump PAsm2_End '<- place this at the end of each InLine PAsm ' for a convenient way to calculate program ' length '' InLine PAssembly code example 3 ''################################################################################################ PAsm3 long PAsm3_End-PAsm3 '<-first value must contain InLine PAsm program ' length in longs mov temp0, #%11111111 'make first 8 bits of temp0 HIGH shl temp0, #16 'shift temp0 left by 16 mov dira, temp0 'use temp0 as a mask to set the 'direction of the LEDs on the Propeller 'Demo Board mov temp0, par 'First par address contains the size 'of the InLine PAssmebly program... add temp0, #4 '...we don't want that so we move to 'the next long to get the address for ARG0 rdlong temp1, temp0 'This reads the contents of ARG0 into temp1, 'effectively passing ARG0 into PAsm shl temp1, #16 'This block of code alligns the data we mov outa, temp1 'passed into PAsm to the position of the 'LEDs on the Propeller Demo Board so we can 'see the bit pattern PAsm3_End '<- place this at the end of each InLine PAsm ' for a convenient way to calculate program ' length '' InLine PAssembly code example 4 ''################################################################################################ PAsm4 long PAsm4_End-PAsm4 '<-first value must contain InLine PAsm program ' length in longs mov temp1, #%11100111 '<- Some value we want to pass back to Spin mov temp0, par 'First par address contains the size 'of the InLine PAssmebly program... add temp0, #4 '...we don't want that so we move to 'the next long to get the address for ARG0 wrlong temp1, temp0 'This reads the contents of ARG0 into temp1, 'effectively passing ARG0 into PAsm PAsm4_End '<- place this at the end of each InLine PAsm ' for a convenient way to calculate program ' length PRI Inline(StartAddress) ''Call Inline PAssembly function InlinePAsm := StartAddress ' run InLine PAsm code repeat until InlinePAsm == 0 ' wait until code is finished DAT '' InLine Assembly Engine starts here ''################################################################################################ ''################################################################################################ org 0 PAsmEntry loop rdlong SpinPAsmAddress, par wz 'wait for InLine PAsm if_z jmp #loop movd PAsmPointer, #InlineProg 'Restore/Set the self 'modifying pointers 'Destination' 'field to the beginning address 'of 'InlineProg' '' Load InLine Assembly from Spin '################################################################################################ rdlong ProgramSize, SpinPAsmAddress 'determine size of InLine 'PAsm code in longs +1. Note: 'This value is one more than 'it should be (remember Zero 'counts) in order to append 'the 'jmp #Done' footer code 'at the end of the InLine Pasm 'code. add SpinPAsmAddress, #4 'Increment pointer to 'start of InLine PAsm code rdlong PAsmDatafromSpin, SpinPAsmAddress 'get first long of PAsm code 'from Spin PAsmPointer mov 0-0 {<-the destination address gets self modified}, PAsmDatafromSpin '  'Self Modify 'InlineProg' at ' │ 'an offset determined by the ' ┌───────┘ ' 'Destination' pointer in ' │ ' 'PAsmPointer' ' │ add PAsmPointer, DestMask 'increment the 'Destination' 'pointer in 'PAsmPointer' to 'the next PC position. add SpinPAsmAddress, #4 'increment the InLine PAsm 'code pointer to the next 'instruction rdlong PAsmDatafromSpin, SpinPAsmAddress 'get next long of PAsm code 'from Spin djnz ProgramSize, #PasmPointer 'decrement the Program Size 'counter and jump if there 'is still InLine code to be 'coppied '' This section places a 'jmp #Done' at the end of the InLine PAsm code '################################################################################################ mov FooterCode, PAsmPointer 'make Copy of 'PAsmPointer' 'at 'FooterCode' (Self modify 'the nop instruction mov PAsmDatafromSpin, Footer 'replace the previously read 'InLine PAsm instruction from 'Spin with the instruction 'located at 'Footer' which is 'the 'jmp #Done' FooterCode nop '<- This line gets self modified to append 'jmp #Done' to the end of 'the InLine Pasm code '' Area defining the location of where the InLine Assembly will be '################################################################################################ InlineProg long 0[50] {<- the Inline PAsm program area is reserved to 50 longs, but you can change that to whatever the program allows or whatever particular need you have} '' Clear Flag and Jump to the beginning of the InLine Assembly Engine where we can wait for more code '################################################################################################ Done mov flag, #0 wrlong flag, par jmp #PAsmEntry Footer jmp #Done '<- This line never gets executed here. It's placed 'as a reference so that upon compile time the calculated 'value in this location can be used in the self modifying 'code section to add a 'jmp #Done' at the end of the 'In-Line PAsm code block. '' Variables used for InLine Assembly engine '################################################################################################ SpinPAsmAddress {<- note missing long ; this notation causes 'SpinPAsmAddress' and 'flag' to be aliased to the same variable in memory } flag long 0 ProgramSize long 0 PAsmDatafromSpin long 0 PAsmDataAddress long 0 DestMask long %1_000000000 '' If your In-Line Assembly uses any variables you need to place them here!!!! ' The reason has to do with the way the variable locations are calculated upon run time. ' you can add as many as the program will allow, and you can use whatever names you wish ' as long as they don't conflict with the names used above. '################################################################################################ temp0 long 0 '<--- These are to be referenced from within the Spin Inline Asm temp1 long 0 '<--- These are to be referenced from within the Spin Inline Asm DAT {{ ┌─────────────────────────────────────────────────────────────────────────────────────────────────┐ │ TERMS OF USE: MIT License │ ├─────────────────────────────────────────────────────────────────────────────────────────────────┤ │Permission is hereby granted, free of charge, to any person obtaining a copy of this software and│ │associated documentation files (the "Software"), to deal in the Software without restriction, │ │including without limitation the rights to use, copy, modify, merge, publish, distribute, │ │sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is │ │furnished to do so, subject to the following conditions: │ │ │ │The above copyright notice and this permission notice shall be included in all copies or │ │substantial portions of the Software. │ │ │ │THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT│ │NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND │ │NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, │ │DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, │ │OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │ └─────────────────────────────────────────────────────────────────────────────────────────────────┘ }}Humanoido
http://obex.parallax.com/objects/635/
And some sample objects
http://obex.parallax.com/objects/636/
Massimo
I haven't fully absorbed what you have done there but it possible to get rid of the need for manually tracking jump target addresses by using ORG. Like this snippet which creates the correct run time jump address in the Pasm1 routine:
DAT 'bla 'bla 'bla InlineProg long 0[50] 'The Inline PAsm program area is reserved to 50 longs, 'bla 'bla 'bla org InlineProg 'Use org to adjust jumps for 'correct run time address PAsm2 long PAsm2_End-PAsm2 'First value must contain InLine PAsm program 'length in longs mov temp0, #1 mov dira, temp0 :loop xor outa, temp0 jmp :loop temp0 long 0 PAsm2_End 'Place this at the end of 'each InLine PAsmBasically what you have here is a PASM overlay loader controlled from Spin, sneaky.
Anyone who wants to do this should check out the tricks used in Cluso's overlay loader. From which I learned the ORG thing:)
Don't be. This is "Propeller Land" where impossible things are done every day.
Notice some idiot in this thread hastily replied "Not at all." to your question:)
It has indeed become a roller coaster ride of ups and downs, of yes's and no's, possible and impossible, blinded guessing and grand visions spot on, a place where you'll meet pure genius from above and hot-hard-heads from down below, where fame is fleeting and success is lasting, a place to get flamed one day and praise-honored the next.. welcome to the Propeller Forum!
Humanoido
Humanoido
When I read around the forum the opinion that propeller power hasn't been fully unleashed I was sceptical... while in fact anything considered impossible for the propeller becomes possible in an impressively short time.
There are also a couple of objects around in development that could be described as multitasking, if the word wasn't banned from this forum... :-) It means anyway we will probably have in the near future the possibility to use one single COG in place of the 2-4 COGs required until now for the same tasks...
Both the dispatcher and the inline assy, while not for starters, will bring a lot of power.
Massimo
