Post fixup: Side-by-Side Comparison
Phil Pilgrim (PhiPi)
You can now compare old forum threads and the fixed-up one on the test site side-by-side. Just go here and click on any link (old post -> new post) to bring the threads that contain them up for a split-screen view of both. You can slide the vertical divider left and right, if necessary:
I would encourage active participaiton in this, since I can't possibly look at them all. Picking links at random will ensure that everyone doesn't inspect the same threads. If something doesn't look right, please post either the numbers (old post -> new post) or a link to the split screen for the offending thread here, so I can figure out what's wrong.
I've converted about 10,000 posts so far out of around 415,000 and will continue to update the link site as new ones are added. Once I'm fully confident in my program, I'll throw it over the wall to Jim, so he can run it on-site, which should make things go faster. (As it is, I'm probably approaching thin ice with my ISP.)
I we look on side by side conversions.
And only one thing I can say ---- VERY GOOD work.
