reading a 1.1v signal with the Prop?
Hello All:
I'm trying to read the data and CLK pins on a 1.5v LR44 battery powered device.
I can see the CLK and the data using my Parallax usb O-scope.The CLK is 77kHz the data is two 24bit words.
My problem is I have not been able to create an amp. or voltage level shifter with a high enough input impedance like the one used in the Parallax O-scope to send a valid signal to the Prop.
So far everything I have tried places to much load on the data or CLK pins and the device shuts down.
(the LR44's are new and read 1.7volts with my Fluke 87-V)
Any ideas or help would be greatly appreciated!
When the device outputs 0V, the Prop will see 1.34V; when it outputs 1.1V, the Prop will see 1.99V.
This is excellent Mr.Green.
I did a quick check through my organizer drawers and viola, I have 3 LM339's on hand.
I think I understand the high impedance voltage divider, Know after reading Your post reply a few times.
I'll bread board this circuit and see how it works.
Many Thanks!!!
Thanks for the reply PhiPi
This is close to what I started with. I later found that just the touch of my hand on the data or CLK pin would add enough load to shut down the tiny device.
The data sheet, gives the CLK speed and the info on the data, two 24bit word LSB first,Thats it.
The first word starts with a 55uSec start bit and ends with a 55uSec stop bit. So I see 110 uSec between words.
The CLK-out in the data sheet shows 90kHz, I read it as 77kHz with the Parallax O-scope.
I have pulled the parts to set-up Mr.Greens circuit. I'll give this a try,And report back with my findings
Thanks for all the help so far!
Though maybe I misunderstand the problem - are you reading digital or analog signals? If digital, then any logic gate would work.
It seems odd that the signal is so fragile. ? another cause for it not working, eg a noisy power supply.
Thanks Doc.
If the LM339 doesn't do the trick it give it a try.
