ATTN KYE - DS1307 RTC engine — Parallax Forums
edited 2010-09-10 07:13 in Propeller 1
Kye,
I tried a couple of DS1307 objects but yours was the only one that seemed to work.
I have made a version of your RTC driver which allows setting/reading the DS1307 in 12 hour mode (in addition to 24 hour).
I have other programs (for Basic Stamps and Arduinos) that use 12 hour mode so that is why I wanted to try it in SPIN.
It works great but I have a question.
Your methods have comments like "6 Stack Longs" etc.
What exactly does that mean and how did you calculate the value?
- Ron
  • KyeKye Posts: 2,200
    edited 2010-09-10 06:48
    Basically that's a stack usage hint to tell you how much stack space calling that function will require.
    So, if you were running out of memory you would have a good idea then of how large the stack needed to be for a cog...
    I calculated that value using the wisdom provided by Chip Gracey in one of the webinars. He said, that every functions needs 3 stacks longs plus one for every local variable and argument. So... using that info I then just built up the stack estimate for each function. You'll find that its in the ball park of how many stack longs each function uses.
    Thanks for the explanation Kye.
    I thought maybe you had some sort of analysis program that calculated the memory requirements.
    I might expand this code some more to handle the DS3231 RTC alarm capabilities but there are a lot of options for setting alarms...
