6 digit glass LCD panel, direct drive from Prop?
Heater.
A store near here as a couple of hundred 6 digit glass LCD panels on clearance for 1 Euro a piece. So of course I had to pick one up.
It has 50 pins DIP style rather like the 60D070 here http://www.femacorp.com/products/lcd/glass%20panels/glass%20panels%20index.htm
So how to drive this from our favourite MCU?
What I have gleaned so far:
1) One common pin and 49 segment pins.
2) Needs AC drive, no more than 100mv or so DC component.
3) Common pin driven from 50 to 200Hz square wave
4) Segments driven from in phase or anti phase signal makes them OFF or ON.
5) Contrast can be varied by changing "dead time" in signals. Patent held by STC.
So one Prop has enough pins to drive only half of this. Two Props would be a waste. Some kind of output expander is called for.
Anyone have any neat ideas for this? DIP solutions preferred, in keeping with the display and y Props.
Anyone know any more LCD secrets to keep in mind.
Here is an app. note from STC describing how to drive seven segment LCD panels in software from an MCU's general purpose I/O pins.
www.st.com/stonline/books/pdf/docs/6292.pdf
The Prop has nowhere enough pins for a 6 digit non multiplexed display with one common pin and 49 segment drive pins. So some external hardware is required.
As I'm old fashioned so my first thought is to use six 8 bit serial in parallel out shift registers like 74HC595. In DIP packages at 50 cents a piece they match the style and cost of the display and I can actually bread board the thing.
These can be chained together so now we only need 2 Prop pins to drive 48 signals out. Or up to 5 pins if we want control of output enable, output latch, and reset.
Using the output latch is a good idea as it syncs the segment drive outputs with the common pin drive. Both square waves at 100Hz remember.
48 is one output short so we can sacrifice a decimal point or I have to drive it from another Prop pin.
Is HC the right technology for Prop interfacing?
http://pdf1.alldatasheet.com/datasheet-pdf/view/166617/MOTOROLA/MC145003.html
I think there were smaller ones.
That MC145003 is not good here. It drives 128segment, multiplexed by four LCD panels. This panel is not multiplexed so there would only be 32 segments usable from it. Perhaps there are similar devices but I have my heart set on DIPs.
However you were right in suggesting 4000 series, which I noticed before you edited it away.
Locally I can get CD4056 which is a BCD to 7 segment decoder + input latches + it does level shifting so the outputs can be bigger than 3v and can be adjusted for contrast.
Then there is 4543 BCD to 7 seg with latches but no level shifter.
There are a couple of other LCD drivers without latches which is no good if we want to save pins.
These are still six chip solutions though. Looks like I have to scour the catalogue some more and do some experiments.
I used to use some BCD to 7 segment LCD drivers and some cmos xnor gates for a similar but only 4 digit display. the backplane was driven with 50 Hz.
Even the BCD to seven segment LCD drivers would require 12 bits of BCD data to come from some where. That's 12 Prop pins or again it's serialized with three 8 bit shift registers.
So to minimise Prop pins and chips and the amount of hand wiring to do it looks like the shift register idea is not so bad. It also means one can drive segment patterns that are not just "0" to "9" "A" to "F".
Question remains is the 3v available enough to get the LCD to work?
I'm thinking that HC series logic will work up to 6v. Driven in anti phase gives a 12v peak to peak across the segments which surely is enough.
This would only possibly 2 or 3 pins on the Prop. The 6 volts could be derived from a charge pump and adjusted for contrast. Two or three transistors could take care of the level translation from Prop to the HC.
That's a good point re: voltage and multiplexing.
I have never lit up a naked LCD panel before (if that's a good expression for it) so this is all new to me. It was a surprise even to find out that I need AC drive yesterday.
First experiment will be to drive common and a few segments from two anti-phase outputs from the Prop. Wish I had a signal generator around.
First experiment is a success. Two Prop pins driven in anti-phase at 100Hz lights up the LCD segments really dark, if you see what I mean:)
Now to get some shift registers.
This is going to be quite neat, the shift registers will sit underneath the LCD panel.
Actually there is a nice 595 driver object in OBEX which I will kick off with.
It's kind of spooky being able to get segments displayed just by touching the 100Hz output from the Prop with one hand and some random display pins with the other.
"...50 Hz are all around us"
Wow, you are right. By touching the displays common pin to a good ground, like the tap in the kitchen sink, and then holding the kettle lead with one hand I can "light up" the segments by touching the display pins with the other hand. Great experiment.
Not sure if 3.3V will be enough to make it very dark but give it a try.
Bean
