Where is the Pin 16 in the BS2? For Serial communication
I know my question will sounds dawn for most of you, but why everybody use pin 16 for Serout in the BS2 if the Bs2 only have P0 ~ P15 ? where is the mysterious pin 16? I dont see it?
Gracias!
Gracias!
Update: I finally though I beat Mike Green to the punch, but I stopped and check the manual. Oh well.
Don't get too fancy with response please! just tell me where is the pin 16 to connect a wire to the PC.
Gracias again.
DEBUG and DEBUGIN assume an inverted 8-bit 9600 Baud signal on SOUT and SIN. You don't have to specify any of that.
Thats more clear. So I will say the Pin 16 means to send data connected to Sout/Sin pins in the Bs2. Good to know.
Gratzie tutti
