Tips for working with Enclosures?
I've recently started to enclose my project in standard plastic enclosures. The simple act of creating a number of holes in a box that are well aligned and spaced has proven to be more difficult then I initially thought. Normally I start by designing and printing a template. I then apply that template to the box and center tap each hole to be drilled. After center tapping I use a small "hobby" drill (hand held manual drill) to make a guide hole. Last I drill the full sized hole with an electric drill. This has provided acceptable results but I was wondering how others approach enclosures. Also, what techniques do you use to apply lettering?
Thanks!
Tim
Thanks!
Tim
Making a presentable enclosure is often the hardest part of project. Cutting rectangles, squares (and other non-round openings) can be a real pain.
I have a drill press which helps with precision drilling plus you can feed the bit very slowly so it doesn't grab.
I recently bought a digital caliper from Harbor Freight for more precise measurements.
You can buy nice LCD mounting kits with a clear center and black edging for attractive LCD mounting.
Radio Shack has some LED holders that improve the appearance of standard size LEDs.
Digikey carries a nice assortment of project boxes - I like the ones by Hammond Mfg.
I like your templete idea and I have used that method also. Frontpanel Express where you can order a drilled and lettered panel from supplies free software to layout the panel and I have used that to make the templete I taped to a panel or box. I think they still exist.
For lettering Avery label maker with white on clear or black on clear. Does not look store bought but works.
I have seen some real good almost store bought looking done by using your PC and a cad or paint program to make label you glue on the box.
Tom
http://www.frontpanelexpress.com/
Rest one point of the caliper on an edge of the enclosure, lock the caliper in place with the thumbscrew, the score the surface. These things have very sharp points and will scratch almost anything.
then place a thin sheet of clear
plastic in front of it. You get a really
professional result. You can drill the
holes using the printed front panel
as a guide. A small drill press is a must
to get things exactly right.
Buy standard plastic boxes that have
a front panel that fits into a slot. You
can then use one thin clear panel as a
back panel and drop your printed panel
in front of it and then slide in the clear
front panel.
Cooling with a water drip system is useful, though a bit messy.
And finding other drill bits than the standard twist drill may help. I use a wood working twist drill that has a point in the middle for centering, but cuts the outside edge first. And there are some specialized plastic drill bits that are useful.
Slow speed and low pressure are always necessary with thermoplastics. You never want to melt.
Ultimately, I usually end up doing a lot of hand work. If I need a flat straight finished edge or surface, a mill bastard file is a useful tool. Trimming and smoothing the edges of large sheets can be easily done with a carpenter's block plane. Cut is often done with a hacksaw and the blade is set up to cut on the pull rather than the push for better control. A hand drill saves me the trouble of dragging power cords and frustrations of too much speed.
Improvise, and workout those inevitable [measure twice, cut once...]eccentricities, with a small round file, a cross-cut file, and a nibbler, invaluable.
Post Edit -- Masking tape, too. Plot and mark your stuff out on it. It protects your surface during your work. Any adhesive residue comes off with isopropyl.
