A serious robot power train
LoopyByteloose
I ride a 125cc Yamaha motor scooter everyday. They are very good 4 cycle engines complete with turbo charge for more power and automatic transmission in the form of a belt drive.
What I am wondering is if anybody has ever considered using the power train (the back wheel with attached motor, exhaust, rear brake, etc. as a drive for a serious robot.
The have electric starters. Mine even came with a rf remote that not only locks the ignition, but will remotely start the scooter.
And you call yourself a Canadian?! :smilewinkgrin: It is only too cold to ride if there is ice, and even then there are exceptions.
Rich H
I'm just waiting for the day that happens in real life, in case you couldn't tell.
It never gets cold enough here to need remote starting. It is one of those idiotic 'Asian' features. On my previous scooter I finally had the wire to the starter cut so the feature was disarmed. (I need to do that again.)
But the point is the whole engine and drive wheel is a unit on the rear swing arm. One can remove the unit and provide a whole new frame and steering (think about a tricycle with two wheels up front). About the only minus is you have one less brake.
One could make some sort of go cart or autonomous robot.
About the only thing that would be hard to do is have the single wheel be front-drive. That would require getting the engine to run in reverse (it is pusher, not a puller).
The main idea is that you might cheaply come across one to salvage if someone crunches the front end or is hit from the side and destroyed the frame and the plastic body. We see these kind of wrecks all the time in Taiwan and usually the power train remains in good working order, but their is no way to rebuild the bike (available for pennies on the dollar as your local wrecking yard).
Too bad it's not a 2-stroke,This would have made adding "reverse" a lot easier to deal with.
Tony
I never said 65 mph! 80kph is usually tops (that's 50mph for you Americans (the rest of the world is metric)).
I wouldn't run the 2-stroke motor on gas and 2cycle oil.This has been banned in the U.S. on new production engines because of the pollution aspect About 8 years ago.
A far better alternative is methanol alcohol and castor bean oil (a vegetable oil). Over Gas. This combo burns super clean, And it has a very high octane rating.
Since when has Taiwan or China cared about pollution?
I just had to get my Yamaha checked for air quality (I have to get re-certified every two years). They impose a fine of $60USD for not doing so, but the check is free.
