Keyboard object with CTRL or ALT keys
I am trying to figure out how to work with CTRL or ALT key combinations. So far I have not been able to get any results.
Has anyone been able to work with these combinations?
TIA
Chris
TIA
Chris
I did not bother to fully understand what the Keyboard Object was doing when I did my 1-pin version, but IIRC I had an option in my code to remove the keycode translation. It may be a little easier to read than the keyboard object. See the Tools section of the OBEX under Debug 1-pin TV & Keyboard.
I will check into that.
Chris
So if you press Ctrl + Space you get $20 + $200 = $220
Alt+"1" : $431
and so on..
Andy
After reading your reply, I quickly read through the description data 4 times before seeing what you referred to - it sure was there! Now I just have to do some testing to see how it all works out!
Thanks!
Chris
