Is the serial backpack from Sparkfun....
Buck Rogers
Hello!
Is the Sparkfun Serial Enabled backpack for LCD displays compatible with the LCD functions for the BS2?
This is covered here:
http://www.sparkfun.com/commerce/product_info.php?products_id=258
I have both the backpack and the parallel LCD display so I don't need to track them down. I suspect the display is compatible with the BS2.
:mad:
Incidentally the beginning baud rate for the backpack is 9600 baud.:mad:
:mad:
Those commands are for using a BS2p, BS2px, or BS2pe to control a parallel LCD (and they are not available on the other flavors of BS2)
The Sparkfun backpack is for using serial commands to control a parallel LCD, using a single I/O pin.
In short, they're two different solutions to the same problem, and there's no reason to use both at once. If you have the serial backpack, you don't need the LCD commands - you control the LCD through SEROUT commands, just as though you were writing to the screen (well, I suppose you'd use DEBUG instead, but it's the same thing).
If you have a 2p, 2pe or 2px, you can use cheaper parallel LCDs without the backpack, though you do need to use quite a few of your I/O pins to control it that way.
If you already have the backpack, you should be able to connect it to your parallel LCD, and easily control it using the BS2 and the SEROUT command (and possibly some SERINs as well).
Thank you!
' {$STAMP BS2} ' {$PBASIC 2.5} lcd_cmd CON $FE 'command prefix lcd_cmd2 CON $7C 'special command prefix clrLCD CON $01 'Clear entire LCD screen displayOff CON $08 'Display off displayOn CON $0C 'Display ON noCurs CON $0C 'Make cursor invisible ulCurs CON $0E 'Show underline cursor blkCurs CON $0D 'Show blinking block cursor curpos CON $80 'set cursor + position (row 1=0 TO 15, row 2 = 64 TO 79) scrollRight CON $1C scrollLeft CON $18 curRight CON $14 curLeft CON $10 #SELECT $STAMP ' Select Baud constants #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T4800 CON 188 T9600 CON 84 T19K2 CON 32 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T4800 CON 500 T9600 CON 240 T19K2 CON 110 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T4800 CON 813 T9600 CON 396 T19K2 CON 188 #ENDSELECT Inverted CON $4000 'Value for inverted serial format Baud CON T9600 '+ Inverted 8,N,1 inverted LCD CON 4 i VAR Byte SEROUT LCD,Baud,[lcd_cmd, displayOn] SEROUT LCD,Baud,[lcd_cmd, clrLCD] SEROUT lcd,Baud,[lcd_cmd, curpos+6, "AAA", lcd_cmd, curpos+68, "BBBBB"] SEROUT lcd,Baud,[lcd_cmd2, $0A] 'ctrl-j Save Splash screen PAUSE 2000 SEROUT LCD,Baud,[lcd_cmd, clrLCD, noCurs] SEROUT LCD,Baud,[lcd_cmd, curpos + 0,"Test line 1"] PAUSE 500 SEROUT LCD,Baud,[lcd_cmd, curpos + 64,"Test line 2"] PAUSE 1000 FOR i = 0 TO 5 SEROUT LCD,Baud,[lcd_cmd, scrollRight] PAUSE 500 NEXT FOR i = 0 TO 5 SEROUT LCD,Baud,[lcd_cmd, scrollLeft] PAUSE 500 NEXT 'Backlight values: 128-157 SEROUT LCD,Baud,[lcd_cmd2, $8C] '40% backlight PAUSE 3000 SEROUT LCD,Baud,[lcd_cmd2, $96] '73% backlight PAUSE 3000 SEROUT LCD,Baud,[lcd_cmd2, $9D] '100% backlight PAUSE 1000 SEROUT LCD,Baud,[lcd_cmd2, $80] 'backlight off SEROUT LCD,Baud,[lcd_cmd, displayOff] END ' Finished.
